Date: 09-05-26  Time: 04:15 am
Author Topic: Rough warm up?  (Read 26002 times)
Rough warm up?
« on: 03 March 2013, 05:22:49 pm »
Over the last few days i've had to persevere with the bike to get it to warm up, mainly at the initial start up.
It's very throaty after hitting the button and i have to coax it in to life with the tiniest amount of throttle.
Once it's cleared it's throat i let it tick over for a couple of minutes then i'll warm it up by riding, but even that takes another 5 minutes.
The thing that's confusing me is that it's been fine all over winter with the really cold weather, but today for instance was way warmer than we've been used to and it's been starting like a pig.
The battery's okay, no issues there, and once it's properly warmed up it behaves absolutely fine.
Got a newish K&N fitted, and the bike's used 5 to 7 days a week so it's not sitting about.
For the record i initially started the bike today with a Moto GP end can on, but then put my old Quill race can back on and went for a spin and everything felt good.
Any thoughts please ?
Just read this on another forum:
Re: Engine Rough at Start Up
Update - funny thing....after doing a valve adjustment on my ST1100....found 2 valves were on the tight side...at the limit but not below the limit....guess what ? Two shims later they are all back in exact specs now and NO more rough start-ups. Only did it on very cold days and for very short time. Passing this on as a tip to check your valve clearances if you are having these symptoms.
philshaq
Re: Rough warm up?
« Reply #1 on: 03 March 2013, 09:06:18 pm »
Hi Darrsi, can't really add any advise outside of checking the valves as your update says, I did have a question though, do you start with or without the choke? I use mine through the working week and always start it on the choke for 30 sec.
Re: Rough warm up?
« Reply #2 on: 03 March 2013, 09:10:44 pm »
I've never used the choke, never needed to.
philshaq
Re: Rough warm up?
« Reply #3 on: 03 March 2013, 09:15:38 pm »
ah right. Might be worth a bash to see if it clears its throat a bit quicker.
Re: Rough warm up?
« Reply #4 on: 03 March 2013, 09:27:17 pm »
I'll try it in the morning, too much air would aim at not enough fuel or an air leak, although once it warmed up it ran perfectly well so that doesn't sound too likely in theory??
I've had an air leak before via a carb intake rubber not being refitted properly and it causes hesitation on hard acceleration, it wasn't doing that today!
philshaq
Re: Rough warm up?
« Reply #5 on: 03 March 2013, 09:32:20 pm »
Yeah you're right, doesn't make much sense if its working fine when its warmed up. What makes you think its getting too much air?
If there is something a-miss then starting on the choke might just hide the problem rather than cure it and get it back to starting as you are used to, which I'm guessing you're aiming for.
I use the choke out of habit so tomorrow will try it without!
Sorry I can't be of more use.
Re: Rough warm up?
« Reply #6 on: 03 March 2013, 09:37:52 pm »
I was just explaining an air leak as an example, and what happens.
I'd imagine as soon as i touch the choke the engine will just cut out, at a guess, i'll let you know tomorrow?
philshaq
Re: Rough warm up?
« Reply #7 on: 03 March 2013, 09:42:55 pm »
sounds good.
Re: Rough warm up?
« Reply #8 on: 04 March 2013, 09:49:42 am »
Bike started on the button this morning, and it was much colder than yesterday, then it got a little bit throaty so i tried the choke and it just cut out straight away, which i expected.
It felt a tiny bit better than yesterday but i'm still not convinced that it's quite right, although again once warmed up it was fine?
Definitely way too early to even consider worrying about the K&N filter, so i'm still a bit stumped as it never used to play up in the mornings at all?
Ebme Geek
Re: Rough warm up?
« Reply #9 on: 04 March 2013, 10:11:08 am »
What I find with mine is it will fire up without choke absolutely fine, but as I put the choke on to hold an idle while it warms it will die unless I give it some teasing on the throttle, couple of gentle blips norm does it and aim straight tor 3/4 of the choke, then it will sit there warming up fine and I can back the choke off by the time I get out of the drive.
Strange how it dies as the choke is applied, I will have to see if I can find details of the choke circuit, It's fine going off the choke slowly.
Re: Rough warm up?
« Reply #10 on: 04 March 2013, 10:49:12 am »
I've never needed to use the choke before so i wasn't really expecting that to help, mine's normally the same, a few blips then it would tick over on it's own no problem at all.
And it doesn't normally take as long to warm up which is why it's so noticeable to me.
His Dudeness
Re: Rough warm up?
« Reply #11 on: 04 March 2013, 11:14:17 am »
Just check all the basic stuff first. No harm checking the valve clearance while you're at it but I'd say if it was a valve clearance problem it would be more of a gradual problem rather than it's fine one day and then the next day it won't start properly
Re: Rough warm up?
« Reply #12 on: 04 March 2013, 11:32:50 am »
semi blocked pilot jets in the carbs  ;)
Re: Rough warm up?
« Reply #13 on: 04 March 2013, 11:37:37 am »
@His Dudeness, i've never personally checked valve clearances myself before, is that a pig of a job to do?
@red98, if there was a blockage in the carbs would it not run roughly all the time, even after warm up?
His Dudeness
Re: Rough warm up?
« Reply #14 on: 04 March 2013, 12:11:22 pm »
I don't think it's a clearance problem but if you want to check them it's handy enough. The service manual goes through it quite well so have a read of that first. Getting the cam cover off can be a bit fiddly because it hits the thermostat. You can remove the thermostat but you'll have to drain the coolant or you can just unbolt it and you might be able to get the cover out with the thermostat loose. Then take out the plugs and remove the alternator cover. Then rotate the engine and line up the marks are per the manual so you're on the compression stroke on cylinder 1. Check your clearances and rotate the engine again. It's all in the service manual. You'll need a set of feeler gauges and the engine has to be totally cold. The only place you can go wrong is when you're loosening and tightening the cam cover bolts. If you make a balls of it don't blame me :lol
Re: Rough warm up?
« Reply #15 on: 04 March 2013, 12:15:31 pm »
two sets of jets in the carbs,pilot jets take care of the slow running,main jets then take over at anything above tick over
hey dude...ive managed to get the cover off before without upsetting the thermostat....it is a bit tight though :D
His Dudeness
Re: Rough warm up?
« Reply #16 on: 04 March 2013, 12:17:07 pm »
 ;) bit of swearing will probably get it out :lol
Re: Rough warm up?
« Reply #17 on: 04 March 2013, 01:04:40 pm »
Probably why i've never done it before, the problem i have is being on call for work at weekends so i can't just start taking the bike to bits in case i have to go to work straight away. I normally have to borrow a bike from my mechanic and let him do the fiddly stuff.
I just checked and the valve clearances were checked 14000 miles ago, not sure how often they should be checked.
Re: Rough warm up?
« Reply #18 on: 04 March 2013, 01:06:55 pm »
were they checked or adjusted 14000 miles ago  :)
Re: Rough warm up?
« Reply #19 on: 04 March 2013, 01:44:55 pm »
Don't actually know, 'cos i had a few things done to it at the same time?
The weather's gonna warm up for a whole TWO DAYS so i'll be interested to see if that makes any difference at all in the mornings as well.  :sun
philshaq
Re: Rough warm up?
« Reply #20 on: 04 March 2013, 08:16:05 pm »
Interesting comments about checking valve clearance and adjusting, convinced me I can do it when the bike comes off the road in a couple of weeks.
One final point on the choke, you should always put the choke on before starting,otherwise the engine will flood.
I know that isn't darrsi's question, but thought it worth mentioning. Good luck finding a cure, carb jets sounds like a good call. Keep us updated.
Dead Eye
Re: Rough warm up?
« Reply #21 on: 05 March 2013, 11:32:37 am »
Both of mine have done this - I usually have to hold the revs up a bit, and slowly apply the choke until it holds the revs itself. After that its fine :)
simonm
Re: Rough warm up?
« Reply #22 on: 05 March 2013, 11:58:34 am »
My Fazer doesn't ever start from cold without the choke.  If I do try it the bike is not at all happy to the point where I remember to turn the choke on.  It literally takes 30s-60s before I can turn the choke off and rev without the engine dying.
http://www.horizonsunlimited.com/hubb/tech/using-choke-when-starting-up-51636
"When the engine is cold some of the fuel it gets from the carburettor condenses on the walls of the combustion chamber, so the mixture becomes too lean. The choke compensates for that. It will also open the throttle slightly, compensating for the fact that the engine needs more force to turn, because the oil is cold."
Can you tell me what RPM's the engine runs at idle ?
Does it run roughly ?
When it first starts, if you give it throttle does the engine die ?
My personal opinion is that you should always have the choke on (when the engine is cold) before pressing the starter and that it should run for a minute or so before turning the choke off, testing the throttle, and finally pulling off (allowing the heated grips to warm up too ;-)
Just my uneducated 2p.
Simon
simonm
Re: Rough warm up?
« Reply #23 on: 05 March 2013, 12:08:20 pm »
I just wonder if the idle is too high, that's all.
Re: Rough warm up?
« Reply #24 on: 05 March 2013, 12:36:50 pm »
Idle's about 1200rpm, and when warm is steady as a rock.
The main point of all this is that i've never had to use the choke before, and it's always started first time, and then ticked over quite happily after a quick blip of the throttle.
But within the last week it's suddenly become throaty on start up, which for my bike is out of the ordinary, so i'm just wondering why, especially as the weather is warmer now and it didn't misbehave at all during the really cold weather?
My previous bikes tended to prefer cold weather, whereas the Fazer thrives on warmer climates, which makes it even more puzzling.
Don't get me wrong, it starts, and eventually warms up and runs fine with a bit of nursing, it's not like i can't start it or anything, but there's always a reason when something changes and me being a fussy sod would like to know why!  :)
