Date: 24-04-26  Time: 22:55 pm
Author Topic: Exup cable replacement cheap alternative ?  (Read 5144 times)
b1k3rdude
Re: Exup cable replacement cheap alternative ?
« Reply #1 on: 03 March 2013, 11:55:48 am »
ta.
sadlonelygit
« Reply #2 on: 03 March 2013, 12:48:46 pm »
nipples not up to it..............where have i heard that before!
portboy
« Reply #3 on: 03 March 2013, 01:28:37 pm »
sorry fella did'nt mean to piss on yer chips........ :o
Topcat2006
« Reply #4 on: 03 March 2013, 05:37:07 pm »
They wont sell them as they cannot get the nipples to stay on.  I ordered some in December only for them to call me and then refund my payment as they knew they would not work....
Tom
Sent from my GT-I9300 using Tapatalk 2
b1k3rdude
« Reply #5 on: 03 March 2013, 06:10:54 pm »
If you change those grub-screw ends for one that you solder on and use those end at the servo end, I imagine they should work fine.
If a soldered nipple can stay on the end of a clutch cable then it should work for the exup cable. The issue with those 2mm grub screws by the looks of it is you can screw them in tight enough. That and if the cable outers are poorly adjusted then stress is being undully places on said nipple screws etc pulling them out.
Topcat2006
« Reply #6 on: 03 March 2013, 10:50:25 pm »
Venhills reason was that the heat of the exhaust meant the solder went fluid and the nipple would fall off.  Apparently Yamaha use a higher temperature solder which they dont have and rhwy did not reccomend the grub screw ones as the heat caused the grub screws to work loose....
Tom
solorider
« Reply #7 on: 03 March 2013, 11:56:46 pm »
Tom
Why not get the ends brazed on,then they won't fall off
Topcat2006
« Reply #8 on: 04 March 2013, 06:10:38 am »
I got the feeling that anything other than doing it normally was way outside venhills comfort zone and something they did not want to do....
b1k3rdude
« Reply #9 on: 04 March 2013, 10:48:33 am »
well another option I'm guessing would be to use a pushbike cable repair kit, but again I don't know the temp range of the solder used.
I got curious so looked up various temps -
normal solder - 190c
silver solder - 450c
silver brazing - 600c
Brass brazing - 900c
Copper brazing - 1100c
So I wonder what temp the bottom of the headers gets too..?
sadlonelygit
« Reply #10 on: 04 March 2013, 11:39:48 am »
several peeps have used the venhill soldered kit and reported swift failure of the nipples, hence why venhill don't offer it any more.
with the r&d required, investment in tooling etc for brazing against potential sales it's not worth their while putting their reputation on the line when it focc's up.
better off finding a decent s/h set............and funnily enough :D
Tmation
« Reply #11 on: 04 March 2013, 03:17:30 pm »
The heat required for brazing damages the small diameter cable so the cable will snap just on the outside of the nipple. Best thing to do is swage them on with a hydraulic press.
b1k3rdude
« Reply #12 on: 04 March 2013, 04:45:05 pm »
  • You say brazing temps would be too high, how about silver soldering @450c? would the little cable survive that..?
  • I wonder how hard it would be to source another inner with a nipple made from higher temp solder? and then put the grub screw nipple at the servo end..?
  • Would the inner/complete cables from an FZR/YZF/R1 fit the FZS..? the idea being if the cables new are cheaper than the FZSs then its another option..
tex
« Reply #13 on: 04 March 2013, 08:37:58 pm »
I think we might be in luck with these, i was reading in classic machanics, there is a company making exup cabels for the older exups, and i think the early r1, im at work at the mo, so will go though the mag when i get home, and post later or tommorow.
                      Tex
b1k3rdude
« Reply #14 on: 07 March 2013, 01:51:38 pm »
Hey TEX you got that info mista..?
tex
« Reply #15 on: 07 March 2013, 08:29:52 pm »
 Yes found it today, it is venhill, they are doing replacement cables for the exups, not sure if it includes our one. I am going to  give them a ring over the weekend, as the pevious posts on here said they were not very good , and stopped making them. It was advertised  in  the mag a few months ago, so i would presume it is new!!
                          tex
