Date: 01-05-26  Time: 12:13 pm
Author Topic: what did you do with your fazer today ?  (Read 2358104 times)
Liroka
« Reply #125 on: 12 March 2013, 09:44:40 am »
Fitted a shiny new brake disc.  :D
stevierst
« Reply #126 on: 12 March 2013, 05:23:18 pm »
Ignition barrel siezed up this morning when I was trying to get home after a 12 hour night shift!!! I knew it was dodgy, but this was just siezed solid. Luckily a biker mate of mine arrived with a can of de-icer and flooded the barrel with it. 10 minutes of wiggling and twisting the key I managed to get the ignition on.
 Soaked it in WD40 when I got home, but can't trust the bugger now.  :(
Chris
« Reply #127 on: 12 March 2013, 05:35:48 pm »
sanded down my downpipes because i'd painted them and it had run a bit in some places. Just need to give them another, thin, coat of paint then maybe a small sand and polish then they'll be done! primed fairing bracket so that's ready for painting and depending on how that process goes i'll be ready to finish sanding and painting my lower forks!  8)
CharlieDee
« Reply #129 on: 12 March 2013, 11:34:21 pm »
Hey Liroka. Looking at the fzs600 section recently it seems that you're the only person to get the old disc off without destroying the wheel :lol What method did you use to get the old allen head bolts out?
Liroka
« Reply #130 on: 13 March 2013, 12:08:38 pm »
Ahem, I ended up using the Fazer Spares method of removing the bolts.  ;) :lol
Chris
« Reply #131 on: 13 March 2013, 12:14:17 pm »
I got all 3 of my discs off, the front ones were ok, just one that rounded off so cut a slot in the head of the bolt and used an impact driver with flat blade screwdriver head to remove it. The back one was a bugger and only 2 bolts came out ok, tried the method I used on the sticky front bolt but the heads split in half and half of the head went flying. So I used a chisel and hammer on the half of the bolt head remaining and tapped it around until it came lose. Needless to say I'll be replacing all the bolts when I put the discs back on!
Chris
JZS 600
« Reply #132 on: 13 March 2013, 12:20:57 pm »
Sounds grim,,,,,, :'(
Chris
« Reply #133 on: 13 March 2013, 12:27:59 pm »
Haha, it was a bit of a pain but only took about 10 minutes more than it would have if they'd come out like they should. Could have been a lot worse  8)
Chris
« Reply #134 on: 14 March 2013, 09:36:03 am »
An excellent method of bolt removal :D
andydrz
« Reply #135 on: 14 March 2013, 09:02:59 pm »
Fitted Renthal sprockets after going to Halfords to buy a 36mm socket. Interestingly, the Renthal rear was a third of the weight of the steel one which was on there. Then fitted 'go faster' rim tape......  :)
Jazz999
« Reply #136 on: 14 March 2013, 10:15:28 pm »
Cleaned and lubed the chain, looked at new chain & sprocket kits on fleabay
ChristoT
« Reply #137 on: 14 March 2013, 10:19:07 pm »
Sorted my suspension!
swem
« Reply #138 on: 14 March 2013, 10:31:54 pm »
cheers charlie dee  gonna get me one o them    they look great
Tilts
« Reply #139 on: 15 March 2013, 06:15:12 am »
Had rear hangers and frame protectors powder coated black, some sexy black swinging arm bolt covers of devilsyam, acf50 the whole bike....
« Reply #140 on: 15 March 2013, 11:52:49 pm »
Saw the odo clock up the ton-fifty.
The M3 at 11:30pm in the pissing rain is not a good place to stop, so the photo had to wait 'til I got home.
Chris
« Reply #141 on: 16 March 2013, 12:15:47 am »
WOW!! That's amazing! Must be one of the highest mileage fazers about.
Chris
demic77
« Reply #142 on: 16 March 2013, 12:00:54 pm »
Bought it  8)  Pics to follow when it gets delivered next week. Red 03 foxeye  :D
Mutleyx
« Reply #143 on: 16 March 2013, 04:56:52 pm »
Did headlight mod, washed it, adjusted and oiled chain
Skippernick
« Reply #144 on: 16 March 2013, 06:59:56 pm »
Pass my IAM test on it. :woot
« Reply #145 on: 16 March 2013, 10:32:51 pm »
Congratulations!!
Chris
« Reply #146 on: 16 March 2013, 10:34:54 pm »
Nice one, congrats!  8)
Skippernick
« Reply #147 on: 17 March 2013, 09:52:59 am »
I thank you.
Now where are my pipe and slippers.
XTremo
« Reply #148 on: 17 March 2013, 01:28:19 pm »
Froze my nuts off!
Chris
« Reply #149 on: 17 March 2013, 02:45:57 pm »
Froze my nuts off!
Well worth it for a view like that!  8)
