Date: 17-03-26  Time: 06:31 am
Author Topic: what did you do with your fazer today ?  (Read 2162154 times)
Andy FZS
« Reply #4150 on: 08 April 2015, 11:09:42 pm »
Started it up, it stopped itself and now doesn't work  details in new thread
sinto
« Reply #4151 on: 08 April 2015, 11:45:16 pm »
Brushed down and re painted my down pipes, mainly the collector box area but while me brush was wet - as you do.
I actually did it a couple of days ago and the first picture was tonight they look wet but they are not, the second pic is after I got back from a 40 mile spin. The paint needs the heat to fully cure to a mat finnish, its granvile engine black, if you are interested
They look good Mr, what was the actual paint you used?
its granvile cylinder black,  I did say engine but got it wrong here http://www.granvilleoil.com/product_info.php?prod_id=252
Also to add - it comes in small tins but is quite thin and gos a long way, even though its thin it covers well, you could amost paint glass with it, and its hard to see the brush strokes after, I recon you could do your exhaust 3 or 4 times over from 1 small tin
Looks good, think I'll be searching this out and giving them a wee coat or two, but as you say, maybe get even more done, certainly it'll tidy up the downpipes
« Reply #4152 on: 09 April 2015, 12:49:11 am »
Fixed the replacement alarm I got ages ago (turned out it was just a loose wire on the speaker) and fitted it to the bike, so if any scrotes try to unbolt the tank again they'll have the alarm screaming at them :)
Skippernick
« Reply #4153 on: 09 April 2015, 06:53:20 am »
Why does it look like you have bolts in your downpipes?
Because there are! Something to do with gas flow measuring?
I've only even had Fazers with stainless pipes, first time I noticed it. Is that on all stock downpipes then?
Mines an 02 and has them guess so.
stevierst
« Reply #4154 on: 09 April 2015, 10:49:38 am »
Fitted my cheapo Chinese handguards last night, and tested them out this morning in chilly conditions with summer gloves.
Worked brilliantly I'm keeping the wind off, and stopping the wind chill on my digits. It's an autumn/spring must if you commute!
« Reply #4155 on: 09 April 2015, 11:55:35 am »
Pictures please
stevierst
« Reply #4156 on: 09 April 2015, 12:59:05 pm »
Not the prettiest, but they work!
« Reply #4157 on: 09 April 2015, 01:10:04 pm »
Would they still fit I wonder with full size leavers
NorthWestern
« Reply #4158 on: 09 April 2015, 02:05:54 pm »
Tidying the garage I found the bag of broken headlights that came with my bike.  As I sifted the remains for bulbs and useful clips etc I noticed amongst the jigsaw pieces was enough to put the two fairing infills together!  Two hours, a solder iron and some number filler and they are ready to use!!
« Reply #4159 on: 09 April 2015, 07:24:08 pm »
Finally got my 6 sorted, didnt want to start, turning over but not sparking and no ticking from the fuel pump, gave the ignition switch a good soaking with wd40 and then blasted it with compressed air.....brum, brum  :thumbup
« Reply #4160 on: 09 April 2015, 07:27:25 pm »
Not looked at my thou for a couple of months now so thought it about time I gave it a check over...engine paint is peeling bad now so must get this sorted, then I noticed the front caliped soaked in brake fluid  :eek....looks like ive got another job  :\
« Reply #4161 on: 09 April 2015, 07:35:41 pm »
I was reading falcons earlier reply to andy about ignition switches....low and behold you are the proof Red.
Sorry to hear about the thou :(
Andy FZS
« Reply #4162 on: 09 April 2015, 08:27:47 pm »
Got mine working fine now....well almost ,offside indicator not working now. I suppose that will teach me to check everything before I refit the tank. Guess what I'm doing tomorrow.
stevierst
« Reply #4163 on: 09 April 2015, 09:03:31 pm »
There's not a lot of clearance with the shorty levers, so methinks original levers would need some spacers making.
bigbluebear
« Reply #4164 on: 10 April 2015, 08:20:07 am »
Going to take advantage of the sunshine and take a trip up through Loch Lomond to Glencoe and onto Oban.......should be a cracking day out.
« Reply #4165 on: 10 April 2015, 10:23:08 am »
Hmmm I also see that you have the foxeye whereas I am box. It always pricks my ears up when I hear handguards and fazer 600 as they just dont fit without hitting the fairing or somthing else, so when someone says they have fittet some im interested
stevierst
« Reply #4166 on: 10 April 2015, 10:24:16 am »
Erm mines a thou, not a 6. Different fairing.
« Reply #4167 on: 10 April 2015, 10:32:28 am »
Another bit of proof then that they dont fit on the 600, your pictures do not show any obvious thou features it looks like a 600 foxeye although im not that familiar with the look of the 600 foxeye
« Reply #4168 on: 10 April 2015, 11:08:07 am »
The clocks are usual the easiest identifier between the 600 and thou in those sorts of shots :)
« Reply #4169 on: 10 April 2015, 11:20:10 am »
Well thats just it, they look the same other than not having a gold face on the rev and fuel side, I though that was just a foxeye thing
« Reply #4170 on: 10 April 2015, 01:14:05 pm »
The gold face is only a difference between early and late model 600's (as far as I am aware). My first Boxeye ('99) had a gold face but my second Boxeye ('01) has a black face. The actual clocks themselves are different between the 600 and thou though including the faces, dials and needles :) May be harder to spot if you aren't used to the thou clocks though I guess...
HarryHornby
« Reply #4171 on: 10 April 2015, 02:23:20 pm »
I had a fairly average ride into work this morning, but look at the weather today........ can't wait for the (extended) ride home  :)
mickvp
« Reply #4172 on: 10 April 2015, 02:58:44 pm »
Insured and MOT'ed it for another year :D
hairnet
« Reply #4173 on: 10 April 2015, 03:26:02 pm »
Took fazer to seaside  :rollin
hairnet
« Reply #4174 on: 10 April 2015, 03:27:07 pm »
Ffs
