Date: 17-03-26  Time: 06:30 am
Author Topic: what did you do with your fazer today ?  (Read 2162140 times)
Dave48
« Reply #2675 on: 15 May 2014, 04:42:54 pm »
Bought 4L paraffin @ B&Q-last time bought some was 2/6 a gallon (but that was 1965!). Thoroughly cleaned chain and sprockets, relubed & checked adjustment.
Then decided to wash bike followed by a pleasant hour in the sun polishing! Battery fully charged ready to rock & roll tomorrow/weekend :lol
mr self destruct
« Reply #2676 on: 15 May 2014, 07:34:41 pm »
Had a bit of an arse twitcher on the motorway today, dropped a gear to overtake a lorry and my bike just cut out. Dead. During rush hour too.
Managed to coast to the hard shoulder, tried firing it up again and it backfired bigtime before ticking over like nothing happened. Second time it's done that now, if we didn't have a kid on the way I'd be chopping it in for a new FZ1.  :\
« Reply #2677 on: 15 May 2014, 08:05:04 pm »
Refitted the rear wheel after fitting new bearings last night.....wheel spins real smooth, think I was confusing bearing noise with chain noise  :o :o :o.........should notice the difference on the next ride  :D
« Reply #2678 on: 15 May 2014, 08:22:25 pm »
Uh oh that's proper arse twitching stuff mate....have you got an alarm immobiliser fitted???
esetest
« Reply #2679 on: 15 May 2014, 08:24:25 pm »
Hi Paul , did you use a bearing puller when you removed the bearings or a screwdriver , planning on doing mine in the  autumn , so was just wondering if I would need a puller
Refitted the rear wheel after fitting new bearings last night.....wheel spins real smooth, think I was confusing bearing noise with chain noise  :o :o :o .........should notice the difference on the next ride  :D
Andy FZS
« Reply #2680 on: 15 May 2014, 08:42:18 pm »
Went to seaside for an hour came home and spent another hour removing flies and polishing
« Reply #2681 on: 15 May 2014, 08:56:00 pm »
Check your electrical connections. It is possible it is corrosion of connectors or a loose connections.
Procedure below does not require and major skills (not saying you don't have any major skills :) )
Start with the plug caps and work back
Unscrew the plug caps and cut about 10mm off the end and then screw them back in and put the boot back in position.
Lift the tank and take off the coil connection one by one and spray connectors with WD40( don,t spare it) and then put them back on.
As the tank is up open the electrical connections box. Take out each connector in turn pull them apart and treat both plug and socket to liberal doses of WD40.
Put all that back together
Now go the Right hand handlebar switch.
Unscrew the phillips screws and open the switch Spray the kill switch with WD40 operate it on off about 10 times and and spray some more WD40 into it.
The kill switch can be a source of problems if it has not been used for a while.
Now you have cleaned up nearly all the  connectors associated with engine running.
Last bit to do is under the left side panel.
Take off the side panel and pull off the biggest connect block from the starter cut out relay unit.
Spray the both  the plug and the relay connection with WD40.
Put it all back together and restart the bike. Hopefully it starts  :lol
No doubt someone will come back and say this is a waste of time, but believe me from my experience it is a worthwhile exercise.
Let us know how you get on.
You may find some corrosion which needs a little bit of rewiring, but that cane be easily sorted also
« Reply #2682 on: 15 May 2014, 09:18:39 pm »
hi paul..used a good quality drift.two large beearings came out easy, smaller roller bearing put up a bit of a fight, I removed the rollers and plastic holder and carefully split the outer casing....used a socket slightly smaller than then bearing  to knock the new ones in.nice and easy making sure they went in square....2hrs from start to finish, I used an "all balls" kit from wemoto,£40 delivered
mr self destruct
« Reply #2683 on: 15 May 2014, 09:49:17 pm »
I do, and it's played up a bit since I got the bike.  :\
Cheers mate I'll give it a go tomorrow, but it'll mean taking the Mondeo to work.  :'(
« Reply #2684 on: 15 May 2014, 10:52:47 pm »
What type of alarm/immobiliser is fitted?
« Reply #2685 on: 16 May 2014, 12:43:52 am »
I had a couple of incidents like that on my FZ6 a few years back, turned out to be a duff Kill Switch. It was replaced and been fine since.
MarkWales
« Reply #2686 on: 16 May 2014, 05:55:31 am »
Added Wynns Dry Fuel to the tank - no running issues at the moment
mr self destruct
« Reply #2687 on: 16 May 2014, 06:28:15 am »
What I did with my Fazer today was take a crash course in riding on gravel on the way into work. All of a sudden my favourite little country road was resurfaced with loads of loose shit and I found myself sliding all over the place!  :eek
I wonder if there's any special technique?
A Meta 357TV2. It kept blowing the fuse a few times in recent weeks, but it turned out whoever installed it didn't upgrade it, so I sorted that.
Dave48
« Reply #2688 on: 16 May 2014, 06:28:59 am »
See your bike is same "vintage" as mine. When I bought bike last June it came with an alarm/immobiliser which had been fitted from new(2003). Previous experience with the system on my thou playing up at 10 years age decided me to have the fitted system removed & replaced with a new Datatool System 4 Red which my local Yam dealer was doing a special price on. Wasnt going to bother fitting another alarm/immob until my insurance company insisted!
Once you have covered all the electrical possibilities including testing things like side stand cut out switch,clutch switch-IF the problem persists then check your fuel system:-breather pipes/fuel pump & filter & if necessary the carbs. My money is on the alarm/immob! Good luck
mr self destruct
« Reply #2689 on: 16 May 2014, 06:31:03 am »
Cheers mate! It seemed ok this morning, but that's the trouble with intermittent faults.  :\
« Reply #2690 on: 16 May 2014, 08:31:28 am »
I have a Meta357TV2 fitted and is also 10 years old.
Usually the internal battery goes around now and you get 4 short beeps when switching it on which is the indication of the problem. I am waiting for the beeps before upgrading mine.  :) Since I fitted my own I can bypass it very quickly without stripping anything so it never bothers me to much.
You problem sounds electrical since it just cut out, and backfired on starting. Fueling issues present themselves slightly differently
Usually if the side stand or the clutch switch give trouble the engine will not turn over on the starter and everything on the bulb check will light up.
About 8 years ago on the way back from France we stopped for lunch about 60 miles from home and a bike that had worked flawlessly for 2 weeks would not switch on when . Everything dead, I lifted the tank and checked the connections in the box and sure enough there was a corrosion issue on the ignition switch connector. A dose of WD40 (always carry a very small can with me) sorted it temporarily until I got home but I had to redo the connector. When I went through all the other connectors there were traces of corrosion on many of them.. I treated them all with WD and did it again last year as a matter of form, but the initial dose of WD40 had kept the corrosion at bay.
Forgot to mention the Fuel pump has a small black connector under the tank near the pump pull it apart and treat that also.
Rexr
« Reply #2691 on: 16 May 2014, 01:39:34 pm »
Had my new rear tyre fitted and put the bike back to stock gearing  :)
« Reply #2692 on: 16 May 2014, 01:46:54 pm »
Why so -- what did you have before what did you not like
bigbluebear
« Reply #2693 on: 16 May 2014, 01:48:54 pm »
Cleaned and re-oiled the chain, filled it with petrol, gave a test run to make sure all is ok ready for the NW200 tomorrow
Rexr
« Reply #2694 on: 16 May 2014, 04:08:45 pm »
The owner before me put a 15 tooth front sprocket on and I've put the stock 16 tooth sprocket back on as I do a lot of touring during the summer months and the way the bike was felt like it was reving to high, I've never been one for shorter gearing each to their own I suppose lol
Anquetil
« Reply #2695 on: 16 May 2014, 05:25:42 pm »
Lovely weather, warm and dry. 146 miles, from Wrexham to Betws y Coed, Llanberis, Caernarfon, Bangor, Colwyn Bay, St Asaph, Ruthin , home. Quiet on the roads this morning, but busy with traffic heading up the coast as I came home. Lots of bikers out.
« Reply #2696 on: 16 May 2014, 07:26:01 pm »
Im desperate to see llanberis on the bike...never even been in the car.........any pics????
« Reply #2697 on: 16 May 2014, 07:32:41 pm »
Little bit spit & polish before i hit Welshy Walesy Roads in the morning.
Adjusted the rearset for the gear lever,  lowered the handlebars a little bit, adjusted the span on the clutch and brake levers.....added some activ8 to the engine oil.....put some kurust stuff around the fuel filler lip under the cap where it was a tad rusty and gave it a thin coat of wd once dry.
Hardly ever get weekends off....never mind dry ones....when i have an FZ1 ready to ride......actually feels a little bit festive :D
Hedgetrimmer
« Reply #2698 on: 16 May 2014, 08:24:10 pm »
That looks really good Noggy. Have a good one tomorrow, weather should be right for it. I was thinking of loading up the tent again this weekend, but as explained elsewhere, can't really do it now. I managed to get a couple of hours in to clear my thoughts a bit this afternoon though. Over the Lambourn Downs to Wantage, A338 to Hungerford (nice winding stretch with good surface - rare around here!), then a B road route back to Swindon, Highworth, Faringdon and home. Will hopefully get out again on Sunday, no idea where to head though. Maybe the tank museum at Bovington, dunno.
mickvp
« Reply #2699 on: 16 May 2014, 08:32:24 pm »
Rode it to a local spot, the rest and be thankful, then rode it home :)
Just cleaned the bike, and scrubbed the chain and sprockets before 're-oiling as well:
Nice n windey
Clean bike
Chain and sprocket looking a bit better:
