Date: 01-05-26  Time: 14:28 pm
Author Topic: what did you do with your fazer today ?  (Read 2359709 times)
dBfazer600
Re: what did you do with your fazer today ?
« Reply #1350 on: 30 October 2013, 11:47:15 pm »
Tested the ignition wiring and all is fine. Took the carbs off and started to clean them and I is now drinking beer.
Daz
Lawrence
« Reply #1351 on: 31 October 2013, 12:30:38 pm »
Fitted lever protectors on to stop my Oxford Muffs pushing against the levers. Seems to work. Also had new gold DID chain fitted. The last chain lasted a proxy 4500 miles. Expecting at least 12k from this chain.
4500 miles :eek  Fit a Scottoiler... my DID VX chain done almost 16k so far and been adjusted 3 times (two of those was when the wheel was out for a tyre) since.  I did fit a new sprocket a couple of weeks ago (at 15k), but at £8/each that's not a big deal.
Mattsplat
« Reply #1352 on: 31 October 2013, 01:12:23 pm »
4.5K!!
Lubricate your chain man!
You should see at least 30k from a chain...
fireblake
« Reply #1353 on: 31 October 2013, 01:47:05 pm »
I'm in total agreement. My chain has only been adjusted 3 times in about 8000 miles. My scotoiler is off at the moment but as soon as I've got some new clear tube I'll put it back on. I'm using Chain and Cable spray grease nicked from work and it's doing a great job but the fly off is horrendous. I can't believe how filthy the bike has got after the thorough clean i gave it a few weeks back. Our second car is going soon so no more choice between cage or bike.
Mickey
NotAnotherHill
« Reply #1354 on: 31 October 2013, 03:28:11 pm »
4.5K!!
I lube my chain after every ride. It was a cheap chain that the garage put on. The previous DID chain did at least 15k.
Dead Eye
« Reply #1355 on: 31 October 2013, 06:38:03 pm »
Finally finished up the wiring for the heated grips :)
Decided that since work was quiet that I would go out for a ride... but the battery was flat :( So had my first foray into the delight of bump starting a bike... got it on my 3rd try and due to not being very fit had a lack of oxygen in my brain and put the side stand down whilst it was still in gear *facepalm* engine cut out... So off I go and bump it again, got it straight away though thank god...
The battery being flat gave me an excuse to go out for an "extended" play ^^ Had a bit of fun with a random biker who caught up to on the A46 before doing some twisty bits towards Wooten-Under-Edge and back down the A38 for a lazy end to the ride. Weather was miserable, roads were a bit damp and the sky was threatening rain but thoroughly enjoyed going out ^^
paulchucky
« Reply #1356 on: 31 October 2013, 09:31:34 pm »
whilst working my bollox off i dreamt about taking her somewhere in the country and giving her a real good thrashing  :lol :lol :lol :lol
johnnyg
« Reply #1357 on: 31 October 2013, 10:33:07 pm »
Saw a small patch of blue sky and took it as a sign that I had to go out, got about 10 miles and it started coming down in lumps but it's only water and we don't dissolve!
apage16
« Reply #1358 on: 31 October 2013, 10:38:41 pm »
Stalled her in front of a Foxeye rider at the lights opposite the Tower of London. Awwwwwkward!   :o
scubamarkt
« Reply #1359 on: 01 November 2013, 12:15:24 am »
I changed the brake fluid on the front then gave her a nice oil and filter change
tatastha-sakti
« Reply #1360 on: 01 November 2013, 11:09:59 am »
Today some goddamn freak pierced my front tyre. :(((( All daily plans go to hell... :(((((
Grahamm
  • Global Moderator
« Reply #1361 on: 01 November 2013, 05:23:01 pm »
Get some Puncturesafe/ Ultraseal installed. Hole? What hole :)
esetest
« Reply #1362 on: 01 November 2013, 07:05:34 pm »
Refitted the exhaust ( anyone know what the correct torque is for the header nuts  )  , and reconnected the EXUP cables which I labelled T & B , i'm getting forgetfull in my old age .
Also pulled the leads off the plugs and labelled them NO,NI,OI,OO .
mickvp
  • Global Moderator
« Reply #1363 on: 01 November 2013, 07:12:31 pm »
I'm sure I read on here it's 10Nm for the header nuts. I'm sure someone will confirm though
Dead Eye
« Reply #1364 on: 02 November 2013, 08:55:12 am »
Yup, 10Nm for the exhaust studs :) Don't want to put them on too tight
« Reply #1365 on: 02 November 2013, 09:04:12 am »
iam an old foccer aswell....let me think...NO,NI,OI,OO.........MMMMMMMMMM
                                         NEARSIDE OUTER
                                         NEARSIDE INNER
                                         OFFSIDE INNER
                                         OFFSIDE OUTER
see ,told you i was old...i number them,sitting on the bike no1 on the left  ;) [size=78%] [/size]
Andy FZS
« Reply #1366 on: 02 November 2013, 09:51:24 am »
Sitting on the bike no 1 NO...
Yes::)
apage16
« Reply #1367 on: 02 November 2013, 02:06:17 pm »
Smashed through the 50k miles barrier.
brooker81
« Reply #1368 on: 02 November 2013, 02:46:40 pm »
Cleaned fitted black frame covers,put bike on charge and on paddock stand see her next year!!
snapper
« Reply #1369 on: 02 November 2013, 03:51:52 pm »
looks like you've had a misshap over your rear wheel ! a little excited were you ?
esetest
« Reply #1370 on: 02 November 2013, 04:28:13 pm »
Spot on paul , mine are numbered 1-4 as well , but with my memory I would still forget which way I took them off , I was going to label LO, LI ,RI,RO , but that would depend  if I was looking from the front or back .
brooker81
« Reply #1371 on: 02 November 2013, 04:44:59 pm »
Very  :rollin :rollin
Samaha
« Reply #1372 on: 02 November 2013, 05:30:02 pm »
Fitted the hugger my brother got me for my birthday  :)
Next up is getting belly pan painted and fitted....
« Reply #1373 on: 02 November 2013, 08:07:46 pm »
had an un-planned bimble around the thames valley...nice ride and a bonus this time of year  ;)
Gav
« Reply #1374 on: 02 November 2013, 10:38:00 pm »
found some black wax polish for car trim, hiding in the garage.  Took off the black plastic fairing lower inside panels and side bits on the airbox etc and cleaned n buffed em with this black wax stuff.  Was a moment of OCD but fazer looks good.
