Date: 03-05-26  Time: 23:20 pm
Author Topic: Rough Idle  (Read 6198 times)
alexanderfitu
Rough Idle
« on: 14 February 2013, 11:00:28 am »
Since dropping the bike last week, I have had a rough idle.
It didnt start immediately, but its gotten worse.
Heres a vid of the idle, I have the baffle out of my can to make it easier to hear. Does this sound normal?
FZS600 Rough Idle
packie
Re: Rough Idle
« Reply #1 on: 14 February 2013, 11:18:26 am »
Sounds ok to me. Maybe after the fall, you might be homing in on things that wouldn't have caught your attention before the fall???
If you still not happy, maybe a few things to check or do would be maybe empty the float bowls as you may have dislodged some dirt at the bottom of the tank and it could have gotten into your carbs. Might be time to give you carbs a balance too. Also, check that the TPS didn't move in the spill. Can't see anything else that would give a rough idle after a spill. Oh...check your plugs too. You might have fouled them trying to start the bike after the spill. I would take it for a good spin before all that, it might need a good run.
Buzz
Re: Rough Idle
« Reply #2 on: 14 February 2013, 11:40:53 am »
Sounds very much like mine but then again I've got nothing to compare it against!  There's a lot of dur dur dur d-d-d-d dur dur with a rising/lowering note
Cylinder 3 when sitting on the bike L-->R warms up much slower than the rest, I think I need to get a carbtune.
Can anyone post a proper idle vid?
alexanderfitu
Re: Rough Idle
« Reply #3 on: 14 February 2013, 12:02:28 pm »
This is one thats all nice and synced up and idling well:
FZS 600 cam chain tick after
Its defo changed over the last couple of days, this one isnt my imagination :) Maybe I stirred some crab out of the carb bowels when it tipped... :(
Buzz
Re: Rough Idle
« Reply #4 on: 14 February 2013, 12:20:57 pm »
To be honest I don't think there's much difference in tempo, yours sounds a lot brighter but that's probably mic/exhaust etc.
alexanderfitu
Re: Rough Idle
« Reply #5 on: 14 February 2013, 12:41:23 pm »
It sounds like a better version of my xj600:
1991 Yamaha XJ600 rough idle
This bike is nearly unridable at low revs around town, hunts and stutters constantly.
Buzz
Re: Rough Idle
« Reply #6 on: 14 February 2013, 01:28:34 pm »
Ouch...sounds like it's constantly on the verge of stalling, your 600 sounds a lot better.
alexanderfitu
Re: Rough Idle
« Reply #7 on: 14 February 2013, 01:38:06 pm »
Yeah, im prety sure one of the idle jets is blocked on one (or more) of the carbs :)
