Date: 07-05-26  Time: 12:10 pm
Author Topic: Battery Chargers  (Read 6439 times)
arch33angel
Battery Chargers
« on: 22 October 2011, 04:51:20 pm »
Hi, has anyone any recommendations for a good battery charger? Been meaning to get one for ages but there are so many out there it's a minefield. No doubt some are good and some are crap. Thanks, David.
solorider
Re: Battery Chargers
« Reply #1 on: 22 October 2011, 06:38:21 pm »
Major Rant
« Reply #2 on: 22 October 2011, 10:42:46 pm »
Depends how "techy" you want to get and how cheap you want to be.
Optimate is good if you've got £50-£80 to spare and you want no hassle - just leave it connected.
I use a Lidl 500mA battery conditioner thing that cost £5. - I have it on a timer (1 hour a day)
It tops the battery up to 13.5V and then stops charging. For most purposes its as good as an optimate.
I used to use a standard car battery charger with a 10 ohm series resistor and monitored it with a voltmeter
(that cost £0.00)
Avoid:
- A car battery charger directly connected to the battery.
- Any charger or "trickle charger" for "small batteries" that doesn't self-limit at 13.5V (There are plenty out there )
- All solar battery chargers unless you KNOW that they cut off at 13.5V
(There is a lot of bollox talked about solar battery chargers - the phrase "current limited" is meaningless)
(Come to think of it ... there's a lot of bollox talked about battery chargers generally)
(But then ... there's a lot of bollox talked generally  :rollin )
born to be mild
« Reply #3 on: 23 October 2011, 09:55:51 pm »
I recently got a Dr Bike battery conditioner which cost me around £25 sorry,I cant remember where it came from but I think I got it via Amazon, google it anyway It works fine as you can leave the battery connected and it will top up as its a proper conditioner not a trickle charger which I nearly bought as unlike the good Major Im crap with electrics, for instance I used to connect my Speed triple's battery to a car charger like a pillock which soon saw it off !
