Date: 24-04-26  Time: 22:56 pm
Author Topic: Gen 1 - anyone fitted a quicker action throttle?  (Read 3685 times)
JayB
« on: 08 February 2013, 09:42:07 am »
Was thinking this last time I rode the bike, seems to have a lot of rotation, so wondered if one from an R1 or similar would fit and make any difference?
stevierst
Re: Gen 1 - anyone fitted a quicker action throttle?
« Reply #1 on: 08 February 2013, 01:39:06 pm »
I made and fitted one to my Tiger 1050 due to having to 'overreach' to get full throttle. It made a difference to that bike and well worth it. You just have to be a bit more delicate on the throttle input when normal part throttle openings.
Easy to make, and almost free.
JayB
« Reply #2 on: 08 February 2013, 05:11:19 pm »
I would have thought someone had done this before to the Gen 1 and would know of a swap item?
slimwilly
« Reply #3 on: 08 February 2013, 06:51:17 pm »
How do the diy actions work?
fireblake
« Reply #4 on: 11 February 2013, 05:38:55 pm »
I've thought of doing this as i have babies hands.
Mickey the bumper
stevierst
« Reply #5 on: 11 February 2013, 05:44:23 pm »
Ill see if I can dig out the photos when I finish work.
stevierst
« Reply #6 on: 11 February 2013, 09:12:25 pm »
I cut and pasted this from the Tiger1050 forum where I posted it in October last year.
How to make a 1/4 turn throttle yourself.Tools needed:-
Phillips screwdriver.
10mm and 8mm spanner.
Hacksaw
stanley knife
Araldite or similar glue.
medium grit sandpaper.
35mm UPVC plumbing pipe.
Stage 1, removing the throttle tube. loosen the cable adjuster in front of the ignition barrel. Unscrew the two phillips heads screws from the throttle housing and remove. Split the housing and remove the cables. Remove the bar end weight and Slip off the throttle tube.
And here it is!
Stage 2, making the throttle spacer. You now need to get yourself some 35mm UPVC plumbing pipe. Mine was 2mm wall thickness, but there is plenty of room for much bigger. I cut a piece of pipe 1/8" wide or thereabouts with the hacksaw and sanded the burrs off. Cut a slot in the pipe so that it looks a bit like this.
 Then trim the piping so that it fits snug onto the throttle housing with no gaps.
Just like this.
Once the fit is right, lightly score both the outside of the throttle body, and the inside of the pipe to give the glue something to grip to, and use an epoxy resin type glue such as Araldite to bond the piping in place. You can see in the photo that I made a little cutout guide for the cable to track along. Not really necessary with pipe this diameter, but I did it anyway.
Then leave it to dry. Once dry, trim off any excess glue from the end and inside the tube recess where the housing fits just to make sure it doesn't snag. You can use the stanley knife and sandpsper for this.
Stage 3, the refit
Refitting is just as easy as disassembly. Place the throttle tube on the bar, refit the cables, clamp the housing over the top and place the screws back in tight. Adjust the cable to your desired tension, refit the bar end and Voilla!! Instant 1/4 turn throttle! There is enough room in the housing for much thicker tubing to be used, which will further reduce the ammount of tube travel to give you full throttle, but that's up to you to experiment with it. I'm happy with this much turn, as will most of you.
Enjoy! :001:
fireblake
« Reply #7 on: 12 February 2013, 05:09:47 am »
Nice one Steve, I'll enjoy reading this lots of times thinking it looks so easy.  :lol
Mickey
stevierst
« Reply #8 on: 12 February 2013, 05:38:48 am »
Its not that hard Mickey, I only lost a couple of fingers doing it :lol :lol
slimwilly
« Reply #9 on: 12 February 2013, 06:46:12 am »
Lol, some people,
Good info there, thanks, Billy
ghostbiker
« Reply #10 on: 12 February 2013, 02:06:36 pm »
Might give this a try some time if I get a spare throttle tube.
Easy enough to change back if you don't like it that way LOL
stevierst
« Reply #11 on: 12 February 2013, 03:47:45 pm »
It certainly worked well on both my tiger, and sv650 which both had really long throttle travel. I've never stripped a fazer throttle down, so I'm not sure how it will turn out.
PaulSmith
« Reply #12 on: 13 February 2013, 05:54:48 pm »
If you chamfer the ends of the spacer then you lose less sensitivity at closed throttle openings.
