Date: 20-03-26  Time: 20:10 pm
Author Topic: fitting a belly pan to a gen 1 600  (Read 3229 times)
gordon
« on: 04 February 2013, 10:23:59 am »
hi dudes how easy is it to fit a belly pan ? as i cant seem to find where to fix the back end of it .
any pics would help me alot
cheers lads
Chris
Re: fitting a belly pan to a gen 1 600
« Reply #1 on: 04 February 2013, 10:47:08 am »
Hi gordon,
My belly pan may be different to yours but mine has seperate clips that clip around the lower part of the frame and you screw the bolt into that. Is your belly pan new? if not maybe the person didn't send the clips with it. Hope that helps... sorry can't get any pics at the moment. will try and get one later.
gordon
« Reply #2 on: 05 February 2013, 10:48:20 am »
hi chris yes it is new but they dont give you any fittings which is crap so i,m sure i,ll find away around it , thanks for your answer
Chris
« Reply #3 on: 05 February 2013, 01:06:31 pm »
No worries mate. Have you tried contacting the seller to see if they have just forgotten to put in the fiitings?? might be worth it. I'm sure you'll figure out something  :)
Lazarus
« Reply #4 on: 05 February 2013, 06:15:16 pm »
my belly pan has a set of "runners" that are attached to the frame - the belly pan bolts on to that (accompanied by a lot of swearing as its a fiddly job)
ponkster
« Reply #5 on: 05 February 2013, 06:26:42 pm »
My belly pan took a lot of fiddling to get in the right position - I put all the fittings on loose and then shuggled it about until it looked right - then tightened every thing up .
I can take some photos of the fittings if it would help
gordon
« Reply #6 on: 05 February 2013, 07:34:59 pm »
thanks pics would be great as i dont have them
ponkster
« Reply #7 on: 05 February 2013, 08:39:24 pm »
attached are a pic of the front bracket and the rear bracket - both sides are similar fittings, hope this helps.
Please excuse the state of my bike - its been sitting outside all winter and is due a jolly good spring clean.
ponkster
« Reply #8 on: 05 February 2013, 08:41:00 pm »
for some reason both pics have uploaded upside down ! sorry
gordon
« Reply #9 on: 05 February 2013, 08:56:17 pm »
thanks mate i,m sure i could make them up if not i know someone who can cheers pal
