Date: 24-04-26  Time: 21:30 pm
Author Topic: Clutch lever catching Pass/flash switch  (Read 2372 times)
FuZzBoM
« on: 29 January 2013, 01:45:11 pm »
Hi all, I have just noticed my clutch lever is slightly catching my pass flash switch when you pull it in. not enough to make me flash while changing gear but it is visibly rubbing a flat edge to the switch.
The bike was purchased with a set of renthal bars but in truth I cannot see how the standard bars would make any difference to the lever position.
Does anyone else suffer this problem?
I am wondering if it possibly has a pattern lever or something not being exactly the right shape. It is however tempting me with getting some CNC levers to see if his improves it at all.  :lol
Any suggestions welcomed. thanks
jackojet
Re: Clutch lever catching Pass/flash switch
« Reply #1 on: 29 January 2013, 02:27:40 pm »
I had same problem, simply undid screws in switch housing and rotated it slightly, found a more comfortable position then for operating the indicators. You might find rotating the clutch lever down will achieve the same and a bonus of having a more natural position for using clutch.
I too have renthals and aftermarket levers.
Hope this helps :)
FuZzBoM
« Reply #2 on: 29 January 2013, 06:03:05 pm »
Thanks for the reply. I am fairly sure it has the original levers and I have it adjusted the way I like it.
My thinking was that if i got a set of say http://www.ebay.co.uk/itm/130841388293?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 those would the curve round the top allow it to clear the switch gear?
jackojet
« Reply #3 on: 29 January 2013, 06:36:33 pm »
My levers pretty much same as those, still had to rotate the switch towards rider and lever away from rider, I do have my renthals more towards me than the standard upright position so maybe that may be the difference?  :)
FuZzBoM
« Reply #4 on: 30 January 2013, 08:28:47 am »
Hmm cheers may have a play then. I could not resist i ordered a set of these http://shop.the2wheels.com/CNC-Adjustable-Clutch-Brake-Levers-Set-for-Yamaha-Lever-Set-Yamaha.htm
see if they turn up now lol.
FuZzBoM
« Reply #5 on: 12 February 2013, 10:56:29 pm »
They arrived today. quality looks to be good, fitted without any issues and seem to work great.
Well worth the £23 i paid. at worst they are a cheap set of spares.
I went for the black lever with the blue adjusters and they look great on a blue fazer.
Don't resist buy them today  :D
