Date: 07-05-26  Time: 06:55 am
Author Topic: A question about FZS600 engine noise.....  (Read 15303 times)
packie
« on: 10 January 2013, 01:01:25 pm »
My engine seems to emit noises that are more noticeable from the left hand side when you are sitting on the bike. It's noticeable on cold starts until it really warms up. When you pull in the clutch, the noise goes instantly, or it will go eventually after 20-30 mins of driving after the bike is really heated up.
It also went away after a carb sync. Unfortunatley, the carbs were out not long after the sync and the noise is back again, so the carbs may be out again after being disturbed. Anyway...question is, is this a normal trait with the FZS 600? The valves are perfect and the camchain and tensioner were replace recently. The noise was there before and after the camchain change and it doesn't sound anyway near like a camchain problem anyway. It sounds more like something going on in the clutch especially when it goes away instantly when you pull in the clutch even a little.
Your thouoghts please...............
Pakie
Lawrence
Re: A question about FZS600 engine noise.....
« Reply #1 on: 10 January 2013, 02:45:52 pm »
My clutch is a bit noisy too, I think it's fairly common.  Doesn't seem to affect how it rides.
Jc72
« Reply #2 on: 10 January 2013, 03:49:05 pm »
Every bike I've had make a noise that goes when you pull the clutch lever in, just be grateful you ain't got a Ducati , have you heard the clutch on them, :eek  sounds like a bag of rusty bolts
packie
« Reply #3 on: 10 January 2013, 04:16:37 pm »
Sound lads.....
I have no problem in putting up with the noise, some of my old jap bikes like the Yamaha XS1100 were as noisey as a badgers ass, I just wanted to be sure that it wasn't anything that needs seen to, or could be expensive if ignored down the road.
The bike is running fine and smooth. The only complaints would be sometimes she labours briefly when pulled from very low revs even in 1st or 2nd gear. The other complaint would be the 1st to 2nd gear change. You want to change gear quickly to get a smooth gear change. If it's anyway up the revs, it can sound if it's crunching its way into gear.
JZS 600
« Reply #4 on: 10 January 2013, 09:11:48 pm »
That's the way it goes man, welcome to the club!
« Reply #5 on: 10 January 2013, 09:49:00 pm »
Sounds like you're describing a worn clutch cable to me.
His Dudeness
« Reply #6 on: 10 January 2013, 10:12:59 pm »
ducati's have dry clutches that's why they're so loud.
reillypadraig
« Reply #7 on: 11 January 2013, 12:42:56 am »
It's the exact same on mine. Clutch pulled in and no noise, clutch out and it rattles, thought it was the anti judder springs on the back of the clutch basket, it wasn't. Might be a natural problem with bearings, the new engine I got has only 15,000 on it and already noisey. Must have been that way from almost new
packie
« Reply #8 on: 11 January 2013, 01:10:01 am »
That's a possibility. I noticed the clutch cable wasn't "quite right" and free as ones on other bikes that I had. I picked up a spare and i'll swap them over and see what happens.
Cheers,
packie
reillypadraig
« Reply #9 on: 11 January 2013, 01:16:22 am »
I also have a spare cable if u need one,
Also packie I sent u a pm about that caliper & master cylinder
packie
« Reply #10 on: 11 January 2013, 01:19:40 am »
Sent you a reply, Padraig.
reillypadraig
« Reply #11 on: 11 January 2013, 02:47:47 am »
Never got it man, maybe just send me a text tomorrow at some stage, prob be handier. It's 0833314355.
Still only starting to get the hang of this site haha
Lumpy
« Reply #12 on: 11 January 2013, 03:59:39 pm »
only the ones with dry clutches
« Reply #13 on: 11 January 2013, 11:20:09 pm »
Unless it is the release bearing rattling back through the shaft to the left side.
Mine is more of a slight rumble from the right side at tick over which stops when you pull in the clutch or put your ear plugs in  :lol
Check the sprocket nut because when it goes its own way it can make funny sounds from the left side.
The labouring briefly in low gears could be the TPS out of adjustment.
packie
« Reply #14 on: 12 January 2013, 09:12:21 am »
Maybe I got the "left hand side thingy" wrong because I do have dodgy hearing & my left ear picks up on more. But the rest of my story would be like you described, except I wouldn't describe the sound as a rumble.
Deffo not the nut. This thing happens at standstill & goes away at the point were the clutch is engaged and starts to bite.
Thats something worth checking before I look at the carbs (if I want to go down that road)  :eek
Thanks unfazed for the response.....
Packie
Fazer Jake
« Reply #15 on: 14 January 2013, 06:51:09 pm »
I wouldn't worry, its normal.
