Date: 06-05-26  Time: 00:24 am
Author Topic: How to: heated grips  (Read 2876 times)
alexanderfitu
« on: 01 January 2013, 05:43:23 pm »
I know there are a couple of heated grip fitting guides on here, I have just fitted mine and took some pictures along the way, Hopefully its helpful to somebody.
Linky http://fotifixes.com/2013/01/01/how-to-fit-heated-grips-fzs-600-fazer/
xlewisbdx
Re: How to: heated grips
« Reply #1 on: 01 January 2013, 07:47:53 pm »
Thank you  :)
alexanderfitu
« Reply #2 on: 01 January 2013, 08:41:18 pm »
No worries :)
tosh23
« Reply #3 on: 09 May 2013, 05:02:36 pm »
Just marking this for my own search later...good post OP//
Stooby2
« Reply #4 on: 10 May 2013, 01:23:33 am »
Can I add a point - Step1) Disconnect the battery.  If you're pulling fuses out and doing all that you don't want anything live.
And is that fuse part switched? If it's not you will end up with a flat battery if you forget to switch the grips off when you park up.
alexanderfitu
« Reply #5 on: 10 May 2013, 07:45:06 am »
yup, that fuse part is switched, thats why I went through the trouble of getting the connection from there rather than just going to the positive terminal :)
