Date: 07-05-26  Time: 19:32 pm
Author Topic: oops. cracker.  (Read 7853 times)
Lumpy
oops. cracker.
« on: 24 December 2012, 09:00:54 pm »
Checking and cleaning wheels and brakes today to find a crack in the left disc. Aaagh. Drilled a hole at the end to stop further extension. New discs ordered today. Bugger.
Skippernick
Re: oops. cracker.
« Reply #1 on: 24 December 2012, 09:38:39 pm »
lucky you checked though.
Re: oops. cracker.
« Reply #2 on: 25 December 2012, 07:49:21 am »
You only need one, they work independently!!
Lumpy
Re: oops. cracker.
« Reply #3 on: 25 December 2012, 05:37:30 pm »
indeed but I always replace in pairs
 Same as pads.
bozboz
Re: oops. cracker.
« Reply #4 on: 29 December 2012, 01:31:31 am »
Lumpy are you keeping your old right disc or would you be willing to sell it? Unless thats cracked too...
Re: oops. cracker.
« Reply #5 on: 29 December 2012, 01:51:51 am »
Out of curiosity, what discs did you go for?
Lumpy
Re: oops. cracker.
« Reply #6 on: 29 December 2012, 08:34:15 pm »
rs is fine. Just usual wear. I would keep it but if you need it you can have it.
Lumpy
Re: oops. cracker.
« Reply #7 on: 29 December 2012, 08:37:09 pm »
good question. Made up in Coventry. I'll have a look. Outgoings were Kazagum8 or summit and have been fine for 2 years plus.
bozboz
Re: oops. cracker.
« Reply #8 on: 29 December 2012, 09:05:04 pm »
Cheers Lumpy, sent you a PM  :)
Re: oops. cracker.
« Reply #9 on: 30 December 2012, 08:35:52 am »
That's what i'm using at the moment, the wavy one's, they've been very good and are noticeably thicker than most other discs.
Lumpy
Re: oops. cracker.
« Reply #10 on: 30 December 2012, 05:27:23 pm »
Quote from: darrsi
been fine on mine. All weathers. Loads a miles. Never a problem. Well up until just now. Always yes true. Always good braking. Not bad wear either. Hopefully the Brit made ones will be better tho.
Lumpy
Re: oops. cracker.
« Reply #11 on: 03 January 2013, 10:43:06 am »
Further oops. Replaced same day with Zone Products discs, new pads, and new pins.
His Dudeness
Re: oops. cracker.
« Reply #12 on: 03 January 2013, 03:30:13 pm »
2 years out of a brake disk is pretty crap. lucky you spotted it. a crack that big could have caused a serious accident
Lumpy
Re: oops. cracker.
« Reply #13 on: 03 January 2013, 04:12:18 pm »
oh yes, if it had peeled away it would have been character builing. The showed signs of wear with the original pads but the EBCs and Vesrahs were better. The cost of non-OEM discs I guess. They were in pretty good nick for 30k in all weathers even after the very aggresive first set of pads. No idea why it cracked, I'm not that hard on them really. The crack started on the outside and came in, there has been no knocks or bangs on it, it wasn't twisted either. Who knows. The repeated heating and cooling must have work hardened it maybe.
His Dudeness
Re: oops. cracker.
« Reply #14 on: 03 January 2013, 04:42:08 pm »
probably fatigue failure. maybe caused by a flaw in the material that wasn't visible on the surface. here's a bit about it  http://en.wikipedia.org/wiki/Fatigue_%28material%29
markbubble
Re: oops. cracker.
« Reply #15 on: 03 January 2013, 04:45:27 pm »
thats good job you spotted before it locked up on you or something. what bolts are you using to hold discs on?i thought they were always held on with allen headed bolts(that can be a pain to remove) hope yours are correct stress related etc
limax2
Re: oops. cracker.
« Reply #16 on: 03 January 2013, 08:45:10 pm »
I've had a Zone Products disc on the back for about 5,000 mile now. Still looking good.
Lumpy
Re: oops. cracker.
« Reply #17 on: 04 January 2013, 08:07:56 am »
the screws are proper grade SS 302 or 304 (I forget) to match the 8.8s standard. Some of the screws were damaged getting them out the last time and I fitted these to all 12. I have fitted washers under the heads this time to save graunching the carriers and need to fit the dome headed bolts on the LS to clear the speedo drive.
I will get some new disc screws I think and do all 12. What you need is a good fitting Allen socket, not key, and grease the bolts upon insertion and torque them correctly. Most people overtighten them and that leads to destroying the hex with an ill fitting key when taking them out. If I took the washers out from under them the hex screws clear the speedo drive okay.
I use titanium ones on the other bike but won't invest that on this one but a new standard set for the front maybe, although they are fine as is.
Lumpy
Re: oops. cracker.
« Reply #18 on: 04 January 2013, 08:29:40 am »
It's more likely to be caused by a stress raiser and the many heating and cooling cycles with a touch of work hardening. Due to the type of material used and the manner of manufacture the likelihood of a flaw is remote, although possible. There was definitely something other than use that caused it. Maybe the heat treatment during manufacture wasn't done correctly, maybe a stone hit it square on causing a little nick. I noticed this disc was showing slight corrosion around the periphery where the other side wasn't. Still, this is all conjecture and I am just pleased that it was found and wasn't a catastrophic failure
Re: oops. cracker.
« Reply #19 on: 04 January 2013, 07:04:42 pm »
Reason for that crack is simple looking at the corrosion on the discs and fork legs.
The rivets/bobbins which allow the disc to float have seized from the buildup of corrosion.When they seize the disc cannot move as it should when it expands/contracts and its only option to allow its movent is to crack at the weakest point, which it has.
The pictures also show the disc bolts have been replaced with standard bolts and washers.
When you replace the 2 discs, replace the bolts with the proper ones and overhall the calipers at the same time. With that level of corrosion it is possile the capipers are close to seizing point.
Lumpy
Re: oops. cracker.
« Reply #20 on: 05 January 2013, 09:03:25 am »
Quote from: unfazed l0
thanks. Despite appearances the calipers are free as a free thing and the pistons push back with finger pressure. The crack started at the outer edge too. There is no proper screw to use only usual. The hex bolts are absolutely fine. What reasoning do you have to think otherwise pleasethe fork legs look like that due to recent salted roads. And like I said, despite appearances all of the important things are tip top and no expense spared
Re: oops. cracker.
« Reply #21 on: 05 January 2013, 10:27:02 am »
I use my Fazer which I bought new in 2003 all year round (73500miles) and to prevent corrosion on the lower fork legs I wipe them with a cloth soaked in WD40. Kept away from the disc obviously. The only way I have managed to prevented the corrosion on the rivets/bobins was to rinse them down with water after using the bike on salt laden roads, which could be every evening. I changed my discs at 69000 miles as they were worn and used EBC ones, they make a funny whirring sound which took some time to get used to.
Good to hear the calipers are ok.
This is the type of bolt which should be used when replacing disc with a bit of blue loctite to prevent them loosing.
Lumpy
Re: oops. cracker.
« Reply #22 on: 05 January 2013, 02:39:16 pm »
[/quoteplease would you tell me why I should be using this type of SCREW please? These are more regular and better on the left side to clear the soeedo drive but hrx bolts are perfectly acceptable.  More important to torque them up than use 243.
Re: oops. cracker.
« Reply #23 on: 05 January 2013, 03:35:35 pm »
The head of the bolt is wider than normal and therefore spreads the load better. Generally a bolt without a washer retains its torque better than a bolt with a washer. This is why many automative bolts are flanged and are used without flat washers.
I was not advocating stainless steel, it just happened to be the best picture I had to show the correct bolts.
Lumpy
Re: oops. cracker.
« Reply #24 on: 05 January 2013, 04:29:44 pm »
Gotta be careful with stainless. I use titanium on my other bike. Hex screws are pretty much the same area but the force is in shear so the head area is irrelevant effectively. I will be changing them but 6 of the originals got mangled. The hex HDS have been used for 25 000 miles thus far. Stainless is fine as long as the correct type is used
