Date: 09-05-26  Time: 02:07 am
Author Topic: Bibes  (Read 8724 times)
alexanderfitu
Bibes
« on: 19 December 2012, 12:43:55 pm »
Hi all
I know this engine is known for its vibrations at certain points in the rev range, but is it normal for the fairing to vibrate as well? at about 3500 rpm I get a vibration in the fairing which is really annoying. Any body else experienced this?
alexanderfitu
Re: Bibes
« Reply #1 on: 19 December 2012, 01:06:55 pm »
Dammit, that's meant to say Vibes
JZS 600
Re: Bibes
« Reply #2 on: 19 December 2012, 01:18:21 pm »
I get some between 5.5 and 6K
Can get quite distracting some time  :lol
alexanderfitu
Re: Bibes
« Reply #3 on: 19 December 2012, 01:31:54 pm »
Its a tad annoying, the only annoying thing about the bike :)
His Dudeness
Re: Bibes
« Reply #4 on: 19 December 2012, 01:47:58 pm »
 :eek a vibrating fairing at 3500rpm is the first sign of needing an engine rebuild
alexanderfitu
Re: Bibes
« Reply #5 on: 19 December 2012, 01:49:02 pm »
Dont pull my leg! There's nothing wrong with the engine.
you have me paranoid now, im going to check the rpm that it occurs at.
His Dudeness
Re: Bibes
« Reply #6 on: 19 December 2012, 01:59:33 pm »
 :lol
alexanderfitu
Re: Bibes
« Reply #7 on: 19 December 2012, 02:00:43 pm »
Bloody battery is flat! ARgh will have to sort that out now.
His Dudeness
Re: Bibes
« Reply #8 on: 19 December 2012, 02:03:56 pm »
oh no that's the second sign :lol
snapper
Re: Bibes
« Reply #9 on: 19 December 2012, 02:55:30 pm »
If you bike is vibrating one word of advise !
Dont let the Mrs borrow it you'll never get it back !  :lol
alexanderfitu
Re: Bibes
« Reply #10 on: 19 December 2012, 02:56:01 pm »
HA! Thats why she keeps wanting to go pillion!  :lol
snapper
Re: Bibes
« Reply #11 on: 19 December 2012, 02:58:54 pm »
I've never had a 600 but I think most of them suffer in some way or another , I think this can normally be sorted by balancing the carbs , and Im sure I read once re-torque the engine mount bolts helps ,  but have you check your wheel balancing as well ?
alexanderfitu
Re: Bibes
« Reply #12 on: 19 December 2012, 03:00:22 pm »
I will have a quick check over all the bolts, its new to be so no idea what its previous maintenance was like (apart from a recent oil and a filter change).
wheel balancing appears to be ok, doesn't seem speed related but RPM related, Mostly when im riding around town and roll on the throttle from around 3k +
Re: Bibes
« Reply #13 on: 19 December 2012, 03:17:20 pm »
Mine developed an annoying vibration when the bike was a coupe of years old. I managed to stop the infill panels resonating by gluing some foam rubber to the fairing brackets, but lately some other bit of the fairing has started to buzz at certain rpm and I've not made much effort to try to fix it this time... earplugs are an easier solution. :)
alexanderfitu
Re: Bibes
« Reply #14 on: 19 December 2012, 03:18:57 pm »
I think thats a good idea, I was thinking of going around it with some foam. Just got to get the battery charged :p
Yamazer-92
Re: Bibes
« Reply #15 on: 19 December 2012, 04:15:48 pm »
This also happened to me, could not work out what it was for the life of me and drove me mental. I actually ended up taking the whole front end off except the sub frame and clocks and rode it around the block adding a section at a time to eliminate possibilities. It was all fine until I got to the black infill fairings, one of the plastic weird screw things that holds them to the frame was missing two of its clips and wasn't holding it down properly on the right side meaning it was slapping against the metal fixing. I've bodged it for now with an ugly looking allen fixing and rubber washer but the replacement I bought off ebay this week wasn't the right size unfortunately so I am sending it back with the broken one I have removed in it to see if the guy has any of those, hope that helps
alexanderfitu
Re: Bibes
« Reply #16 on: 19 December 2012, 04:22:41 pm »
Aha I will have a look at the fixings. When you say the black infil do you mean the piece you can see that is on the inside of the fairing as you sit on the bike?
Skippernick
Re: Bibes
« Reply #17 on: 19 December 2012, 06:33:30 pm »
Also check that the clock's electrical connectors haven't moved and are starting to touch the fairing somewhere.
Your symptons are exactly like mine and that was the problem took ages to find it though.
His dudeness, very funny  :lol
bwizz
Re: Bibes
« Reply #18 on: 19 December 2012, 06:50:58 pm »
My 600 has a very slight tingle around 6000 revs ,
After a recent accident which broke some of the clock mounts ,It did not get any worse, Check the carb balance!
alexanderfitu
Re: Bibes
« Reply #19 on: 19 December 2012, 06:57:12 pm »
Have had the carb balance checked recently and it seems ok. I will go down the fairing route first as im sure there is a loose bolt. Its not a bad vibration and there isnt rough running at low rpm at stuttering like my fj which has seriously out of balance carbs.
steeeve66
Re: Bibes
« Reply #20 on: 19 December 2012, 07:30:09 pm »
Get some better earplugs?
JZS 600
Re: Bibes
« Reply #21 on: 19 December 2012, 07:31:52 pm »
It's that tingle that goes straight to the nads  :rollin
alexanderfitu
Re: Bibes
« Reply #22 on: 19 December 2012, 07:33:10 pm »
As does the tank when i brake and slide on the seat. I think the dealer was a little overzealous with the cleaner!
glynblue2
Re: Bibes
« Reply #23 on: 20 December 2012, 12:25:18 am »
ChristoT
Re: Bibes
« Reply #24 on: 20 December 2012, 11:58:42 pm »
Looking at posts, all the Fazers have vibrations at around 6,000 revs, and I've noticed some at 3,000 / 3,500 too. Not that I'm too concerned.
When I get back to Uni in January, I intend to do some tests on my engine. I suspect that 6,000 revs is possibly the 3rd harmonic of the engine's natural frequency, which is what generates the juddering. A friend suggested it could also be standing waves being formed in the carbs. Either way, I'll find out in Jan!
