Date: 25-03-26  Time: 14:42 pm
Author Topic: 02-03 Mk2FZS600 headlight bulb  (Read 2454 times)
SteveMc278
« on: 16 December 2012, 09:50:17 pm »
Hi,
Been advised to stick with a standard bulb, however, has anyone used a Philips X-treme Vision(+100%) for any period of time without suffering any discolouring or melting of the headlight lense unit (within the fairing housing) and without suffering any melting of electrical wiring/connectors or any other adverse affects?
Thanks
Re: 02-03 Mk2FZS600 headlight bulb
« Reply #1 on: 17 December 2012, 12:12:21 am »
Philips say those are designed for plastic lenses... the quartz envelope filters out the worst of the UV.
As for heat... that's pretty much identical to an ordinary QH 55/60W bulb. Since a fraction more energy is leaving the unit as useful light rather than heat, in theory the headlight should run fractionally cooler!
In short, they'll be fine.
SteveMc278
« Reply #2 on: 18 December 2012, 11:09:45 pm »
Good stuff Fazerider. Thanks for the info.
