Date: 11-04-26  Time: 01:17 am
Author Topic: Recommend a good drive chain?  (Read 1878 times)
Grahamm
  • Global Moderator
« on: 02 December 2012, 11:59:48 am »
The original drive chain on my FZ6 Fazer, adjusted and lubed (Scotoiler) lasted around 28,000 miles before needing replacement.
Unfortunately the replacement (which I bought and got fitted by a certain shop by Fratton Bridge in Portsmouth...), although treated the same way, is shot after only about 9,000 miles :(
So can anyone recommend a decent replacement chain and sprocket set that isn't too expensive?
NotAnotherHill
JZS 600
Re: Recommend a good drive chain?
« Reply #2 on: 02 December 2012, 08:23:01 pm »
+ 1
Grahamm
  • Global Moderator
« Reply #3 on: 02 December 2012, 10:17:05 pm »
That looks like a pretty good price, thanks.
Grahamm
  • Global Moderator
« Reply #4 on: 12 December 2012, 04:44:02 pm »
Just to finish up this thread: I got a Gold X Ring DID chain fitted by Vernon's Motorcycles in Portsmouth for £150.
It would have been £145, but there was an extra fiver for a new sprocket nut because the guy showed me the old one where over half the thread had been stripped due to wear over 37,000 miles  :eek
Hopefully the new chain will last 28,000 miles like the original, rather than 9,000 like the replacement!
VNA - BMW Wank
« Reply #5 on: 12 December 2012, 06:40:37 pm »
The front sprocket nut?
There should be no wear on the sprocket nut.  Perhaps it could get damaged due to over tightening perhaps, or perhaps being removed if it's bonded a little, but really it should be fine.  The only wear should fitting/removing and erosion.
The original 600 was well known for the front sprocket coming loose.  Mine did, which was before we all realised it was happening right left and centre.  My front sprocket and washer were mince and the output shaft shagged as well.   I welded a new sprocket on and traded up to the thou.
A couple of things.  Is this still an issue on many models?  Or just something to be aware of at service time, particularly when the chain has been on for a high mileage.
Also of the nut is worn, I'd be concerned about the o/p shaft, did your mechanic make any comment on this Grahamm?
That said if it is damaged, but cleans up and takes the full torque setting, it should hold fine.
Anyway when I replaced the chain and sprocket set on my thou, I put some stud lock on the threads.  Don't fancy riding about with just the chain tension holding the sprocket in place again!
Oh and don't forget there are two different DID X ring specs (I think it's just two) VX (value X ring) and ZVM (super strong long lasting).  They come in black, silver and gold, though everybody seems to sell the gold!
