Date: 10-02-26  Time: 10:30 am
Author Topic: oximiser how looooonngggg  (Read 2819 times)
ddtwelve
« on: 15 November 2012, 08:15:33 pm »
had to take the battery off the bike again it wont turn the bike over but dash will work so been having to jump start run till 6mph hit first gear let clutch out and bang she comes to life again .when i came to take the batt off it was reading 11.5 volts , now its on the oximiser which when first on was all the way up to the yellow light and after a day charging now glows green , how long do i leave it charging to be sure its fulley charged
pete786.u
Re: oximiser how looooonngggg
« Reply #1 on: 15 November 2012, 08:22:45 pm »
I thought they were supposed to fully charge the Battery and then monitor it to keep it in top condition. I could leave my Optimate on for a few days with no apparent damage to the Battery.
Grahamm
  • Global Moderator
« Reply #2 on: 15 November 2012, 08:40:33 pm »
How old is the battery? If one or more of the cells are dying you might be able to get enough charge into it to turn the engine over once or twice, but it'll only get worse.
ddtwelve
« Reply #3 on: 15 November 2012, 10:01:54 pm »
I think it might be the one that came with the bike so might be 7 years old ooops
Grahamm
  • Global Moderator
« Reply #4 on: 16 November 2012, 12:02:47 am »
Probably best to put a new one in, then.
This thread recommends MotoBatt, although I've not used them myself.
fireblake
« Reply #5 on: 16 November 2012, 09:02:33 am »
Just s little advice,  2nd gear is an easier gear to bump start it?
justy1
« Reply #6 on: 16 November 2012, 09:21:58 am »
what, with your little legs mate! lol!
ive had my 600 12 years & it still has the same battery sat in it. its been layed up for the last 8 month coz ive been riding the 1000. now thats broke ive had to get the littlelin out. she started right on the button! :D  i love my 600, she never let me down  ;)  (even though i dont look after her the way i should :\ )
justy1000
His Dudeness
« Reply #7 on: 16 November 2012, 10:17:38 am »
justy1000
slagged him about his legs and then boasted about your own bike. that was a helpful post :lol
2nd gear for a push start. top tip... don't fall over
justy1
« Reply #8 on: 16 November 2012, 11:28:08 am »
justy1000
take it you lot dont have a sense of humour over this side?  :lol
justy1000
ddtwelve
« Reply #9 on: 16 November 2012, 03:28:38 pm »
I don't jump start it in gear as it's easier on slight inclines to get up to speed then clutch in first gear let it out bang bike started haven't had the front end come up yet with all th 10 times I've done it so far ,
Batt fully charged last night showing 13.84 volts so gonna see tonite how far it's dropped:-)
His Dudeness
« Reply #10 on: 16 November 2012, 03:38:21 pm »
justy1000
over what side? yea i thought it was funny thats why i put  :lol
justy1
« Reply #11 on: 16 November 2012, 05:18:09 pm »
justy1000
normally post on the fazer 1000 forum hence the term "on this side"
& i know you do, thats why "i" put  :lol too.......... :lol
justy1000
wfbroddy
« Reply #12 on: 16 November 2012, 06:22:01 pm »
at a voltage of 11.5v then your batterys on its last legs, you can recover a battery from this low voltage as long as all the plates are in good nick, but an Oximiser isn't the tool to do it,
what type of battery is it ?
If it's the old wet style  then get an old fashioned battery charger on it for a couple of hours to put a large boost into it, but don't let the battery get hot, then use the oximiser
If its a Gel style then you can still a car charger but it needs to limit its initial charge
If its a dry cell new fangled thingy then you need that type of charger to put the boost in, which the Oximiser will do but its not got enough omff in it to reverse chemical process
I've always found with these things, use them to put the charge into the battery but once its at full charge, unplug the oximiser, I'm not confinced that the top up function of these units work.
My rules for battery maintenance are simple
keep the battery physically clean
Charge when need to but not on a trickle charge
always followed the above and I've never had to replace a battery, as far as I know my old Buell  a 2000 model is still on its original battery, as was my old 1150GSA 2004 model.
HTH
