Date: 21-03-26  Time: 01:08 am
Author Topic: FZS 600 Oversteer  (Read 8385 times)
Re: FZS 600 Oversteer
« Reply #25 on: 15 November 2012, 09:28:29 am »
Say what you mean Lumpy  :rollin
Lumpy
« Reply #26 on: 15 November 2012, 09:33:34 am »
Quote from: darrsi
eek. I thought that was subtle but to the point  :'(
« Reply #27 on: 16 November 2012, 06:21:19 pm »
One item forgotton here is the rear shock. Is it standard or after market.
If standard adjust the preload to the hardest position and try the bike to see if it has improved. this makes th e bike sit higher at the rear putting more weight on the front
A soft rear shock can take the weight of the front and make it more difficult to turn in.
If it is aftermarket adjust the preload to make it sit higher at the rear.turn it one ring at the time (tighten the spring) to see if it improves.Trial and error so may take a few trys to get it right.
Usually the static sag start point is 25 mm at the front and 12mm at the rear.
spoonlamp
« Reply #28 on: 01 February 2013, 08:33:34 pm »
Check the tyres. A squared off rear makes it harder to turn in.
You and the Dudeness had it bang on. I just put a new front tyre on and she's back to her beautiful smooth cornering  :)
packie
« Reply #29 on: 02 February 2013, 12:49:11 am »
I'd still check the fork oil.......  :rolleyes
would be a bit awkward to do though wouldn't it? he'd have to take the forks out just to check the oil. if you're going down that route you might as well replace the oil
I owned a bike once (can't remember now) that had a little philips screw on the bottom of each leg that allowed complete draining of the fork.....very handy.
kebab19
« Reply #30 on: 02 February 2013, 02:43:00 pm »
Steering head bearings too tight / too loose / banjaxed?
spoonlamp
« Reply #31 on: 02 February 2013, 05:44:02 pm »
Problem solved, many thanks for the help . If threads can be deleted, feel free  :)
Dead Eye
« Reply #32 on: 02 February 2013, 07:01:36 pm »
The information here may assist people with similar issues in the future, its worth keeping it around :)
spoonlamp
« Reply #33 on: 02 February 2013, 07:53:22 pm »
Good point, well presented.
Carry on   :lol
