Date: 09-05-26  Time: 03:50 am
Author Topic: removal of exhuast stud  (Read 6760 times)
gordon
« on: 11 November 2012, 05:39:27 pm »
hi guys dose any one know of a easy way to get a exhuast stud out , its not broken as such cos someone put a
bolt in and the head broke off  ? :'(
thanks guys
dickturpin
Re: removal of exhuast stud
« Reply #1 on: 11 November 2012, 06:03:33 pm »
can you get two nuts threaded onto it then lock the two together and turn the innermost one?
markbubble
« Reply #2 on: 11 November 2012, 06:15:28 pm »
as already mentioned try getting a couple of nuts on it or just one and weld it on,before you try to 'undo' it get some heat in the area withh blowtorch or similar
« Reply #3 on: 11 November 2012, 07:05:11 pm »
as above,as above  ;) ;)
cnw180
« Reply #4 on: 11 November 2012, 07:21:52 pm »
I had a broken stud, but it still had some thread on it. Rather than attempt to remove it I had a sleeve nut made (from a hex nut). It fitted through the header flange on the downpipe to secure it. See the links for pictures...
http://sdrv.ms/ZabQHk
http://sdrv.ms/ZabYXt
http://sdrv.ms/Zac4OI
Hope this helps...
andy352299
« Reply #5 on: 11 November 2012, 07:43:50 pm »
when using the 2 nut method as described above also try screwing the bolt in then out and soaking with penetrating fluid
if you have no luck and before you shear the bolt off flush you could try my method below it sounds like a bodge but has worked in the past.
the biggest problem with drilling out a bolt/stud is keeping things straight and drilling down the middle so heres my bodge.
get 1 m6 sleeve nut or stud connector nut or what ever you want to call it, basically its a long nut approx 15-20mm long,
now find a brake cable adjuster from a bicycle these are m6 thread with a 3mm hole down the middle
now buy a GOOD quality 3mm drill bit .
now you are ready to attack the stud
 screw the nut onto the broken stud, screw the brake adjuster into the stud, now drill take it easy and apply cutting oil/lube
with any luck you will now have a 3mm hole down the middle of the stud
you can now use larger drill bits until you get close to 4.8mm ( the thread tapping size for M6)
if you get really luck you maybe able to pull/pick the old stud out of the engine case with out damaging the thread in the case
hope this makes sense
gordon
« Reply #6 on: 11 November 2012, 10:16:55 pm »
thanks guys i,m going to try the two nuts way first but if the wont work,
cnw180 what size bolt was it made from and size thread  put inside please ?
Andy FZS
« Reply #7 on: 12 November 2012, 04:29:14 pm »
I have a stud extractor it has a hole the stud goes through and then a cam that closes the hole tighter the more you pull. Someone near you may have one you could borrow perhaps :)
Andy
His Dudeness
« Reply #8 on: 12 November 2012, 04:41:37 pm »
i think welding a nut onto the stud works the best
gordon
« Reply #9 on: 12 November 2012, 10:14:10 pm »
hi guys just an up date the two nut way did not work , so i got a bloke at work to make a bolt with the right
size thread inside it so now all i have to do is get it through the hole that holds the exhuast on then job done
the second easy way with help from you guys , thanks for this forum
thanks guys will keep u updated  tomorrow
cnw180
« Reply #10 on: 13 November 2012, 04:07:27 pm »
Sounds like you're sorted then. I think the bolt I had made was an M6 thread, or whatever the standard stud nuts are!!
The hex nut was around 20mm I think, and around 15mm was ground away to allow the bolt to slip through the downpipe header flange..
gordon
« Reply #11 on: 13 November 2012, 11:27:36 pm »
hi well sorted now thanks to u all ,  half filling up to the rim some how i,v 84 miles before it reaches the first mark
when i used to get 60 miles also it dose not rev so much 80 mph revs at 6500 . so very well happy .
it came from www.delkevic.co.uk complate for £299.99p
