Date: 09-05-26  Time: 16:07 pm
Author Topic: Starter gear/clutch  (Read 3142 times)
pointer2null
Starter gear/clutch
« on: 01 November 2012, 08:01:31 am »
Starter is starting to play up in the mornings so looks like it maybe needing attention soon.
Anyone done one of these? Any tips/gotchas etc
I don't think it's the motor - sounds like something jamming.
His Dudeness
Re: Starter gear/clutch
« Reply #1 on: 01 November 2012, 12:54:51 pm »
is it turning over slowly or is it totally locking up?
pointer2null
« Reply #2 on: 01 November 2012, 12:57:23 pm »
Both, will turn slow (like battery flat) then next try will lock, repeat pressing of starting and swearing and suddenly will turn over and start as normal.
His Dudeness
« Reply #3 on: 01 November 2012, 01:24:29 pm »
If the batt is definitely good I'd start with the easiest thing which is the motor itself and also check the gears that connect the motor to the engine for damage. You'd have to take off the starter clutch cover to get the motor out. You could check the bearing that's in that cover, check all the gears and then take out the two bolts that hold in the motor and check if it spins freely. If you want to take the motor apart and clean it and check it is just two more bolts. All handy stuff. If that doesn't work then maybe go on to the starter clutch. I haven't taken one out so I'd be interested in how you get on
pointer2null
« Reply #4 on: 01 November 2012, 01:28:08 pm »
I'll post back when I get round to doing it - may not be for a few weeks though.
JZS 600
« Reply #5 on: 01 November 2012, 02:34:30 pm »
Silly thought, does the starter motor have brushes?
