Date: 07-05-26  Time: 05:34 am
Author Topic: Headlight Mod  (Read 8637 times)
nick
Headlight Mod
« on: 11 October 2011, 05:48:42 pm »
 :D  Just done the Headlight Mod now got two Dipped Lamps, I soldiered the L shaped Female Spade cable on it was easier than unpicking the old cable which i got from another lamp connector.Then run some 1.5mm cable to the Main Connection unit (2000 bike) and then removed the spare Green Male connection from the Black Connector and then connection made using a  Spade 6.3mm Male/Female insulated  outside the Black Block but in the main connection unit.
Have to say without the help from the chap who posted the pics and info i would have needed a lot more help , so many thanks.
Checked coolant level all ok, Oil just change Silkolene 4 and Filter, cleaned the Clutch Lever Pivot and Greased, what a difference that makes.Change next .
chicken
Re: Headlight Mod
« Reply #1 on: 25 October 2011, 04:11:08 pm »
Quote
I'm new here (and to Fazers) and this sounds like something I should do. Have you got a link please?
Orangegrump
Re: Headlight Mod
« Reply #2 on: 25 October 2011, 04:36:49 pm »
chicken
Re: Headlight Mod
« Reply #3 on: 26 October 2011, 03:34:38 pm »
thanks for that Orangegrump.
I didn't actually pick up my bike until last night and pleasantly surprised to see that the previous owner has already done this mod so that's saved me a couple of hundred pounds (because I would try to do it, get it all wrong and then have to pay someone else to sort out my mess).
nick
Re: Headlight Mod
« Reply #4 on: 26 October 2011, 06:12:40 pm »
Pleased to here that Chicken
I have replaced the H1 and H4 Lamps with Phillips Hi-Viz which helps as well, not being sure how to do a link but i got them from here http://www.regalautobulbs.co.uk about 10 Quid each lamp.
I have now changed the oil and filter which was straight forward and next the Gear box oil .
After that gonna strip the Calipers down and re-Pad with new seals clean Dot 4.
The Rubbers on the Carb to Barrel connection are showing signs of splitting but performance is ok at the moment.
Captain Haddock
Re: Headlight Mod
« Reply #5 on: 26 October 2011, 06:45:20 pm »
If you changed the oil and filter you've already changed the gearbox oil, it's the same oil.
nick
Re: Headlight Mod
« Reply #6 on: 27 October 2011, 08:17:56 pm »
I was thinking that may be the case after i posted thanks Captain.
Its me Cage that needs a Gearbox change.
