Date: 09-05-26  Time: 06:11 am
Author Topic: anyone fitted a quickshifter?  (Read 7154 times)
His Dudeness
« on: 26 October 2012, 01:29:22 pm »
I have a quickshifter and it has rose joints on the end of it like in the picture below
I'm just wondering if this type of joint can be used with the ball on the end of the standard fazer shift mechanism or will I have to modify it?
His Dudeness
Re: anyone fitted a quickshifter?
« Reply #1 on: 26 October 2012, 04:52:23 pm »
So I took a closer look at this and I noticed that the little pivoting arms on the fazer and the rose joints on the quickshifter were both M6 so I thought shweeeett I can bin the quickshifter rose joints and use the standard fazer pivoting connectors by just making some studs to connect the quickshifter in. So I made the studs to connect everything up but noooooo! The rear pivoting connector on the fazer is left hand thread and the quickshifter is right hand thread. So I'll have to either get a very short right hand/left hand stud or get a new fazer right hand pivoting connector. But at least I know it will fit and I know what I need to get so thanks for all of your help guys :lol
Skippernick
« Reply #2 on: 26 October 2012, 05:05:20 pm »
2 questions.
1 how does a quick shifter work?
2 how is that a quick shifter?
Thanks
His Dudeness
« Reply #3 on: 26 October 2012, 05:23:42 pm »
they let you change gear without closing the throttle or pulling the clutch in. so you can keep the throttle open and just kick up through the gears. it works by sensing when you kick to change gear and cuts the power to the coils for a split second so the engine unloads and can change gear.
oh you mean the thing in the picture above? thats just a connection that can pivot. if you look at your gear changer there's two of them on it.
caretaker
« Reply #4 on: 26 October 2012, 06:21:29 pm »
what about changing down?
cable tie
« Reply #5 on: 26 October 2012, 06:40:37 pm »
Nap you can only use a Q- shifter for up shifts.
His Dudeness
« Reply #6 on: 26 October 2012, 06:41:26 pm »
changing down you use the clutch. but you can get ones that blip the throttle as you change down so you don't have to use the clutch. there is a video of the general idea
Sportbike Quick Shifter quickshift Triumph 675
Skippernick
« Reply #7 on: 26 October 2012, 06:51:15 pm »
Thanks guys thats cool.
Now i understand.
His dudeness are you getting one then. How much did it cost? I think at my speeds its pointless.
His Dudeness
« Reply #8 on: 26 October 2012, 06:55:37 pm »
yeah i got one ages ago off ebay but i didn't bother fitting it. ah i don't need it either its just a bit of fun.
born to be mild
« Reply #9 on: 26 October 2012, 10:31:36 pm »
I think that you can get rose joints in both RH and LH thread if that helps. I got one of each for my other bike as the Triumph linkage was shot.
cable tie
« Reply #10 on: 27 October 2012, 01:04:08 am »
No no no If you change down without using the clutch you will either do 2 things feck the gearbox up, or lock the back wheel and do this at speed and you go into a skid and probably bin it !! if you want to avoid locking the wheel up you will need to fit a slipper clutch.
« Reply #11 on: 27 October 2012, 01:50:00 am »
I'll be lucky if i get past 20mph on the way to work, i'll give that one a miss........
His Dudeness
« Reply #12 on: 27 October 2012, 12:55:57 pm »
calm down and look at what i said. i didn't say change down without clutching it. i said you can get quickshifters that allow you to change down without clutching it. here's one http://www.flatshifter.com/flat-shifter-pro/
ponkster
« Reply #13 on: 29 October 2012, 07:28:41 am »
A nice looking bit of kit - clever technology - bit of a waste on a Fazer!........... if I ever get a Blade I'll get one!
