Date: 08-05-26  Time: 08:22 am
Author Topic: Brake judder in the wet?  (Read 2653 times)
markaboot
« on: 14 October 2012, 01:13:27 pm »
I was riding the other night in fairly heavy rain in a 30 zone. As I pulled up to a roundabout the last 4 or 5 meters I got what I assume was brake judder. It felt like I lost a bit of braking too and had to squeeze harder.
It only happened once and the bike was fine on the way home but its a little unnerving as I have never experienced it before. The last thing I want to do is go out on a Sunday ride and find I don't have brakes when I really need them.
Has anyone else had this before?
Anything I should be checking?
Thanks
kebab19
Re: Brake judder in the wet?
« Reply #1 on: 14 October 2012, 02:19:26 pm »
Judder with more effort to squeeze lever often = warped front disc. Having said that, if it was warped it should be doing that all the time from now on.
May be pistons sticking in the calipers - when was the last time they were freed off?
« Reply #2 on: 14 October 2012, 04:54:50 pm »
Doubt very much that it's a warped disc, that seems to be peoples immediate response but it's unlikely.
Definitely look towards the calipers being sticky, well worth a bit of TLC if they haven't been cleaned recently.
I had this issue for ages and for me it turned out to be a faulty braided brake line.
But if you haven't got braided lines then there's even more of a possibility it could be standard lines expanding on braking.
I wouldn't be too concerned unless it's a constant thing though!
scottyboy2203
« Reply #3 on: 14 October 2012, 06:20:48 pm »
this may be too simple but are you sure it wasnt a lock up/re-grip moment in the wet? Ive had this before and feels like ABS but is the tyre just skipping on grippy/slippy tarmac. just a thought!
His Dudeness
« Reply #4 on: 14 October 2012, 08:16:41 pm »
could be related to the pads getting a soaking. what pads have you got?
Jamieg285
« Reply #5 on: 15 October 2012, 01:28:06 pm »
Could it have been a bit of crap got between disc and pads, which subsequently fell out, restoring normal behaviour?
Unless it does it again, I wouldn't worry about it.
