Date: 25-04-26  Time: 02:07 am
Author Topic: fzs 1000 carbs  (Read 2928 times)
kev
fzs 1000 carbs
« on: 09 October 2012, 08:58:08 pm »
hi when starting from cold she starts first time but when i use the choke the engine cuts out,and will not run is this problem one of adjustment or is this carbs off job and strip down job and clean out :'(
           thanks kev
Falcon 269
Re: fzs 1000 carbs
« Reply #1 on: 09 October 2012, 11:16:50 pm »
Hi Kev and welcome
It's not unusual for the Gen 1 to dislike choke on start, especially if it's been re-jetted.  If it starts without choke and runs fine, relax and don't lose any more sleep over it. :)
You certainly don't need to pull the carbs or do anything else to them.
Mike
jools
Re: fzs 1000 carbs
« Reply #2 on: 10 October 2012, 09:20:49 am »
Hi i have recently bought one fazer 1000 Gen 1 and found when i put the bike with the choke full out (cold start)  and just hit the starter
it spluters for a few seconds and then picks up revs to say 1K. I then put it into half choke and leave it for  say a 3 mins and it settels down
to a nice idle of 1200K. but when i start it when its warm it just fires up on the button.
is this  normal  for a Gen 1 Fazer 1000 :(
jools
tomlinscote
Re: fzs 1000 carbs
« Reply #3 on: 10 October 2012, 11:41:21 am »
Seems pretty normal to me apart from the 1200000 idle speed :b
If I start mine on the choke it does as you describe but will idle above 2k unless I reduce the choke setting (which I do to get about 1.2k)
P
MEM62
Re: fzs 1000 carbs
« Reply #4 on: 11 October 2012, 10:28:06 pm »
I wouldn't worry about it.  In anything other than the coldest weather my bike starts first time without choke.  I will occasionally then feed in about 1/3 choke once running just to give it a reliable idle while I get my gloves & helmet on.  It's then choke off and off we go.  My carbs have been breathed on by Mike so I know they are tip-top.
