Date: 24-04-26  Time: 16:37 pm
Author Topic: Swing arm bolt  (Read 5735 times)
tomjimtom
Swing arm bolt
« on: 08 October 2011, 11:15:01 am »
Hi, going to grease my swingarm bearings and such, but before I go to halfords an buy every socket between 25 and 32, can someone tell me what size the nut is? :)
Also, do i need to take the swingarm off completely? I've already greased the suspension etc, and got the rear wheel off :)
Thanks
Tom
bludclot
Re: Swing arm bolt
« Reply #1 on: 08 October 2011, 07:17:50 pm »
the swingarm nut takes a 27mm socket. you'll have to remove the arm in order to check / grease the two main bearings. re-torque to 125nm / 92lbft.
if you are local to portsmouth i have the tools you can borrow.
bludclot
Re: Swing arm bolt
« Reply #2 on: 09 October 2011, 09:53:38 am »
when i remove a swing arm i masking tape an old newpaper to the chain side of the arm for removal and re-fitting - it prevents the chain marking the arm.
tomjimtom
Re: Swing arm bolt
« Reply #3 on: 09 October 2011, 04:43:39 pm »
Thanks, got the socket today on the way back from work :)
I'm not local enough I'm afraid, especially with a rear wheel missing  :lol but thank you for the offer.
Looks like I'll have it all apart then, which means EVERYTHING will be covered in grease :)
Thank you again,
Tom
