Date: 06-05-26  Time: 17:15 pm
Author Topic: speedo showing 0mph!speed sensor knackered ?  (Read 3262 times)
Enceladus
« on: 23 September 2012, 04:56:25 pm »
out for a ride today with a group of lads and my speedo suddenlywent from 40mph to 0 and stayed there.
one of the lads said it could be the speed sensor as his did something similar.
he also said that when he took the revs over 10k it would show 0, 4k, actual until turned off and restarted.
got the chance to do this later and mine does the same.
so......
is it the speed sensor ?
if so, where can i get one ?
and ....
are they easy to fit (wherever they are!) ?
green_rider
Re: speedo showing 0mph!speed sensor knackered ?
« Reply #1 on: 23 September 2012, 05:13:44 pm »
The speed sensor is the cable that goes to the front axle. If the sensor is knackered then you need to remove the front wheel to replace it. Its not a huge job if you can prop up the front end with a jack or paddock stand.
« Reply #2 on: 23 September 2012, 06:01:08 pm »
The speed sensor has to have the lugs seated correctly on the left side of the wheel, a common problem is that they snap when not lined up when putting the wheel back on. Only way to check is by taking the wheel off.
I s'pose they could break when moving but that's not too common. Look at #15
http://www.yamahascooterspares.co.uk/spares/epc2.asp?modelID=9657&PageiD=41&m=YAMAHA+FZS600SP+Fazer+METER&uID=0
You may have an issue with the TPS though. For starters check that it's not unplugged itself.
Otherwise, turn the ignition switch on, then unplug the TPS, the black plug type thing sitting on the right side of the carbs, and see what the rev counter does, if it goes to 5000 it's all good.
http://www.cartestsoftware.com/fz1/throttlepositionsensoradjustment.html
Enceladus
« Reply #3 on: 25 September 2012, 10:50:34 am »
will have a look as soon as i get the chance :)
Dead Eye
« Reply #4 on: 25 September 2012, 12:22:36 pm »
This happened to me as well...
First of all, check the lugs as darrsi mentioned. If they are intact then its a bit more of a pain as you likely need the new sender unit. I was quoted £100 for it, but my mechanic suggested looking for a second hand one. I ended up finding someone breaking a Fazer who still had the part which cost me £25 delivered instead - so certainly worth shopping if you can.
The 0k, 4k, actual revs thing is the diagnostics of the TPS telling you that something is wrong. It's described in the owners manual;
Dead Eye
« Reply #5 on: 25 September 2012, 12:23:31 pm »
Argh, double posted, pressed wrong button :(
xlewisbdx
« Reply #6 on: 25 September 2012, 01:24:12 pm »
it could be the rotor sensor on the front wheel. I had a similar problem and the lugs had broken off the rotor sensor
