Date: 12-05-26  Time: 14:12 pm
Author Topic: Engine black  (Read 4051 times)
CliffRose
Engine black
« on: 17 September 2012, 05:30:09 pm »
Hi all......can I ask what's the best engine paint to use as some of mine has come off. I know some of you guys have had to re paint your engines. Do I need high temp paint...
Cheers. Cliff
bikerboys
Re: Engine black
« Reply #1 on: 17 September 2012, 05:46:12 pm »
off my top of my head i fink it was this stuff I used have a look in the fzs600 one of the lads was painting his and tarting it I used the same paint if i find the old post i will put it up there http://www.ebay.co.uk/itm/1-x-250ml-Jet-Black-Engine-Block-Enamel-Petrol-Oil-Resistant-Heat-Paint-Rocker-/290629149663?
bikerboys
Re: Engine black
« Reply #2 on: 17 September 2012, 05:59:57 pm »
 :rollin it will not let me edit the post  :lol any way I have found it now http://www.ebay.co.uk/itm/Engine-Enamel-Heat-Resistant-Paint-Gloss-Black-250-ml-/120965836278?_
that the stuff you need I have used it and still looks good to this day it was recommend by a member on there
and here's the old post http://foc-u.co.uk/index.php/topic,1017.0.html
  adeejaysdelight        Re: Winter
D4Delta
Re: Engine black
« Reply #3 on: 17 September 2012, 06:13:02 pm »
Will it do to paint the exhaust pipes as well? Mine are a bit rusty at the front where they come from the cylinders.
bikerboys
Re: Engine black
« Reply #4 on: 17 September 2012, 06:33:11 pm »
to be honest no it would not be up to the job that bit it dose get hot a lot hotter then then engine this stuff shud do it http://www.ebay.co.uk/itm/125-ml-VQD-Car-Motorcycle-Exhaust-Paint-Matt-Black-Very-High-Temp-Heat-Resist-/120844826584?
just have a look for some hvt black matt or gloss that  Resists temperatures of 650oC intermittently, and 450oC continuously. then you will be ok
manuel32
Re: Engine black
« Reply #5 on: 17 September 2012, 07:30:16 pm »
I have painted exausts in the past, it never works, burns off
Lazarus
Re: Engine black
« Reply #6 on: 17 September 2012, 08:11:06 pm »
tbqfh - i would say use a spray paint - it give a better finish. its a bit of an arse masking off the areas that u dont want paint on, but the finish is better.
Ill dig out the details of the spray I used and post it up.
Panthor
Re: Engine black
« Reply #7 on: 17 September 2012, 09:55:01 pm »
Whats the best way to prep the engine? Do u need to take off all the old paint first?
D4Delta
Re: Engine black
« Reply #8 on: 17 September 2012, 10:06:59 pm »
Thanks for the advice.  :)
David.
Lazarus
Re: Engine black
« Reply #9 on: 17 September 2012, 10:26:58 pm »
i prepped it with wet & dry sandpaper on the bits where I wanted the paint to go - then masked off all the areas where I didnt want it to go
Lazarus
Re: Engine black
« Reply #10 on: 17 September 2012, 10:55:28 pm »
D4Delta
Re: Engine black
« Reply #11 on: 18 September 2012, 12:20:10 pm »
Thanks Lazarus. Website says not available at the moment, but will keep my eyes open.
David.
Lazarus
Re: Engine black
« Reply #12 on: 18 September 2012, 12:29:40 pm »
that link was only to show the paint I used - its available from other places - just do a google search
alan sherman
Re: Engine black
« Reply #13 on: 18 September 2012, 09:35:19 pm »
I'm not the only one that has used smoothrite successfully an I? Works a treat.
