Date: 11-05-26  Time: 05:13 am
Author Topic: fz6 s1 carb/vacum sync  (Read 2363 times)
ddtwelve
« on: 12 September 2012, 10:26:29 pm »
Just had the carb/vacum sync done on sunday set it at 20 with four bar carbtune just had one that was four levels out and a couple with 2 bars reset ,now it seems to run a bit smoother not as much buzzing around 6-7 thou and i can see through my wing mirrors at 80mph, seems weird feels more powerful  :eek
Grahamm
  • Global Moderator
Re: fz6 s1 carb/vacum sync
« Reply #1 on: 13 September 2012, 12:57:20 am »
Erm, that's a good trick because the FZ6 is fuel injected...! :pokefun
ddtwelve
« Reply #2 on: 13 September 2012, 10:14:25 am »
Yep but there is true 4 vacuum hoses underneath the tank which you connect too ,with the tank up you'll see a 2 inch sqaure metal box with numbers 1-4 on it adjustments are made there do not adjust no1 as that's the standard setting adjust all the others to match no 1 then hey Presto ya done ,make sure engine is warm and after each adjustment blip throttle upto 4k leave to settle then check and adjust where necessary :)
BBROWN1664
« Reply #3 on: 13 September 2012, 10:26:37 am »
You are balancing the engine which is correct but the comment Graham picked up on was the fact you mentioend carbs when your bike doesnt have them :pokefun
There is a common problem on the CBF1000 that I am sure would be resolved with a rebalance but the stoooopid foccers at Honda decided that their fuel injection system was intelligent enough to do it automatically and removed the ability to do it as a workshop job. People have tried and ended up buying £1000 worth of new parts to fix it again.
locksmith
« Reply #4 on: 13 September 2012, 01:08:13 pm »
Think you mean balancing the throttle bodies Bob :pokefun
BBROWN1664
« Reply #5 on: 13 September 2012, 05:10:26 pm »
Thats the one. :thumbup
