Date: 25-05-26  Time: 15:16 pm
Author Topic: Does the Gen 1 suffer from the dreaded...  (Read 3024 times)
JayB
« on: 12 September 2012, 10:16:31 am »
...Yamaha white plug on the left hand side of the fairing?
Had this issue with my 5PW R1 recently, it was in quite a state, then yesterday, about 1 minute after the bike having been fired up from cold, the cooling fan kicks off.
Obviously, no guage to go from, so I turn the bike off, get ready to ride off and re-start, 20 seconds later, no fan.
Wonder if it is just a crappy connection causing problems?
Re: Does the Gen 1 suffer from the dreaded...
« Reply #1 on: 12 September 2012, 10:38:58 am »
Think they all do that, try putting it in gear and it should stop.
fireblake
« Reply #2 on: 12 September 2012, 12:59:44 pm »
As Dazza says. Mine does that, after 30 seconds at tick over the fan cuts in but as soon as a gear is selected it switches off. It's perfectly normal. Why though is another question???
JayB
« Reply #3 on: 12 September 2012, 01:24:57 pm »
Strange! I guess a good idea for warm weather and probably because there is no temp guage.
BUT, I did 5hit myself, being that I've just bought her, I was thinking "oh no, it's got no water in it"
 :lol
I checked last night, it has! Cheers guys. Next question coming soon!
Falcon 269
« Reply #4 on: 12 September 2012, 05:50:21 pm »
Yes, the fan is meant to kick in after about 1 minute or so idling from a start.  Put it in gear and it will stop the fan again.  Probably intended as a check to confirm that the fan is operating and to give it a regular spin-up. :)
Yes, the Gen 1 suffers a white connector problem but maybe not the same as the R1 you had.  Not connected to your fan question but you should read this to understand the connector issue.
http://www.yamahafz1oa.com/eskortsdefectiveconnectorreplacement.shtml
While you're in the mood to learn ... ;)
http://www.cartestsoftware.com/fz1/
http://www.yamahafz1oa.com/technicaltips.shtml
Cheers!
Mike
james43
« Reply #5 on: 12 September 2012, 07:27:37 pm »
That's freaky I was going to start a thread about this as mine does it and I assumed it was broken.
Weird.
Glad it's not though lol
JayB
« Reply #6 on: 13 September 2012, 02:54:46 pm »
Cheers Falcon 269 - found the cartestsoftware one, brilliant!
Will check and dielectric grease the connectors I can see under the left, just cause it is a good idea.
