Date: 09-05-26  Time: 03:50 am
Author Topic: Front sprocket issues again  (Read 11338 times)
« on: 09 September 2012, 07:16:50 pm »
 I own a FZS600 which I bought new in 2003 and now has 72000miles on the clock. 3 weeks ago my 5th sprocket nut failed, this time taking all but 2 threads on the shaft with it and the last 2 nuts were the modified nut, even though Yamaha were supposed to have fixed it in 2005. Dubious of the ‘repair’ at the time I tapped the holes in the 2003 sprocket cover to take the plate and damper from the 1998/1999 sprocket cover to prevent the sprocket falling on to the shaft and leaving me stranded again
 Seriously pissed off I contacted Yamaha and under no circumstances would they do anything about it, not even supply me with a new shaft, head and base gaskets free of charge, for me to to replace it myself. They even suggested I spot weld the nut on.
 I spoke to my bike guru friend and he recommended I cut a slot in the shaft and put a circlip on it or drill and tap a hole at the end of the shaft and put a washer and bolt on it to prevent the nut falling off. I did both as a sort of belt and braces job.
 I uploaded what I did with some pictures and since I did not know where to put it I put it under
  Downloads » Manuals » FZS600 Fazer » How I fixed my Sprocket nut problem
Hope it helps
Dead Eye
Re: Front sprocket issues again
« Reply #1 on: 09 September 2012, 08:42:48 pm »
Very extensive and well written, I'm sure it will be helpful to someone :)
ade the blade
« Reply #2 on: 09 September 2012, 08:47:04 pm »
good work that man...........fingers crossed it gives you many miles of worry-free riding  ;)
His Dudeness
« Reply #3 on: 11 September 2012, 01:26:36 am »
yeah nice work. ;) you'll have to give us an update in a few months. i've heard this is a problem with a lot of Yamaha's not just the fazer
« Reply #4 on: 11 September 2012, 08:18:11 am »
Yes it appears to be mostly accross the yamaha 600 range, it appears to be a big issue also with the R6.
 I don't remember hearing of it happening on the 1000 range.
I have covered over 1000 miles sinc I did the repair and it is still ok.
I will keep updating as I will be checking it every 1000 miles or so.
marksfazer
« Reply #5 on: 11 September 2012, 08:53:48 am »
Excellent write up. Well worth doing considering most of us have experienced this problem.
Mark.
« Reply #6 on: 11 September 2012, 12:00:03 pm »
What bothers me is the fact that it can be a very dangerous fault, rather than just some niggly issue.  :rolleyes
« Reply #7 on: 11 September 2012, 07:47:48 pm »
Yes, I agree, the first time this happend to me in 2005 I was riding alone on a quite back road and powering out of a left hand bend when  I lost all drive. The sprocket had fallen onto the threads of the shaft.
Now if that had happened on a busy road or if I was overtaking, it could certainly have been a lot more serious.
« Reply #8 on: 13 September 2012, 11:00:24 pm »
Just to update 1000 miles and still ok
No reply from Yamaha UK yet
« Reply #9 on: 18 September 2012, 12:04:56 am »
Yamaha UK replied and  this was the reply, It was along shot anyway being a different country
Thank you for your email, in relation to your Yamaha FZS600 Fazer.
Naturally we are sorry to hear of your concerns, which have been noted for our files.
We would in the circumstances, kindly suggest that you please re-establish contact with Danfay Ltd on telephone number +353 1 2859177, who being the official Importer and Distributor for Ireland, will be best placed to assist with your enquiry.
Whilst we thank you for taking the time to contact Yamaha Motor (UK) Ltd, we are sorry that we cannot be of any direct assistance.
I asked them for the contact details of Yamaha Europe which they sent me. I will try contacting them also
His Dudeness
« Reply #10 on: 18 September 2012, 01:24:07 am »
in my experience danfay are alright at getting parts but they don't go beyond that. i think they're just importers i don't think they have any actual mechanics but they might be able to direct you on to someone else
« Reply #11 on: 25 September 2012, 10:03:43 pm »
Absolutely no reply from Danfays to my email, will email again. There spares section might be good but their service and sales are crap
Fix still holding after 1300 miles
Paul
« Reply #12 on: 30 September 2012, 02:45:21 pm »
I reckon the reason why the problem with the front sprocket nut exists is as follows:
Minor play between the sprocket and shaft, likely due to shaft being machined with slightly larger grooves than needed.
Nut tightened up on the sprocket.
Sprocket moves fractionally back and forward, and because the nut is tight to it, so does the nut.
Nut threads wear out as do the shaft threads.
Possible solution:  Grind down the over-lap of the nut so it tightens up on the shaft and not on the sprocket.
In essence it should be flush with the sprocket but not tightening up against it.
Ideally make sure there's a layer of grease between nut and sprocket.
« Reply #13 on: 30 September 2012, 08:08:36 pm »
Paul you might be right, I remember a few years ago a friend of mine put the modified nut on backwards after the first nut fell off, he was thinking along the same lines as you he used a 3 mm washer drilled out to fit over the splines between the nut an the tab washer to ensure the tabe washer could the located on the spines properly. There was about a 1 mm gap of play between the sprocket and the washer.
He always thought the nut should not be tight against the sprocket. I checked with him after reading the post and he never had the problem again. He still has the bike but cannot use it due to a back problem and there is 33000 miles and 2 sprockets with the same nut and tab washer.
« Reply #14 on: 03 October 2012, 07:51:39 pm »
Frgot to add in the previous post that he put a rubber washer between the sprocket and the tabwasher
Lumpy
« Reply #15 on: 04 October 2012, 08:02:38 am »
not an engineer are you  :lol
Lawrence
« Reply #16 on: 05 October 2012, 10:18:17 am »
Hope his isn't like mine then, mine fell off at 33500  :lol
Certainly something to think about come sprocket change time.  The best option, regardless of whether the nut is tightened against the shaft or the sprocket, has got to be the circlip/bolt+washer or similar to stop the nut actually falling off if it does come loose.
Lumpy
« Reply #17 on: 05 October 2012, 03:26:48 pm »
Quote from: Lawrence
my TDM had a nylon collar to stop it coming off. Good idea. The sprocket isn't falling off whatever happens.
« Reply #18 on: 11 October 2012, 10:15:15 pm »
Finally recieved a reply from Danfay, they have offered to give all the parts I require to replace the shaft at half price.
His Dudeness
« Reply #19 on: 11 October 2012, 11:04:07 pm »
well that's something at least. what are you going to do?
« Reply #20 on: 09 November 2012, 10:28:34 pm »
 The sprocket fix is still holding after 2100 miles,  :)  which included some lively miles playing with a fellow on a s1000rr after a losing a R1 on the coast roads near home. The s1000rr rider was shocked when he realised he was trying to stay with a 600, when I stopped at a busy cross roads,
This was the conversation
S1000rr rider “Didn’t realise those Fazer 1000s were that quick" My reply "Its a 600" silence and then he says "Jesus you must be ringing its neck"  :rollin   We had a great time for the next 15 miles.
Anyway back to my issues with Yamaha Ireland (Danfay) I took them up on the offer after trying but failing to get them, first to give me the parts at half cost price and then tried for half the trade price. I gave up my haggling when I was asked if I was going to take the offer or not. I suppose after 73000 miles I was lucky to get what I got.
This is the list of parts I ordered:
Quantity          Part number     Part name
1          5DM-11181-00           GASKET, CYLINDER HEAD
1          5DM-11351-00           GASKET, CYLINDER
1          4HM-12213-00           GASKET, TENSIONER CASE
4          90430-10188               GASKET - OIL DELIVERY PIPE
4          3YF-14613-01            GASKET, EXHAUST PIPE
1          93210-12152               O-RING – CRANKCASE
1          90430-06166               GASKET – CRANKCASE
1          93210-06422               O-RING – CRANKCASE
1          4TV-15461-00            GASKET, CRANKCASE COVER
1          4TV-15462-00            GASKET, CRANKCASE COVER
1          93210-48364               O-RING – CLUTCH
1          4TV-17421-00            AXLE, DRIVE
1          93440-30077               CIRCLIP - AXEL DRIVE
1          93102-35368               OIL SEAL - AXEL DRIVE
1          90891-10124               SPROCKET NUT, WASHER, KIT
1          4JH-16340-00             PUSH LEVER ASSY
1          4YR-15427-00            COVER CAP
1          90890-85508-00          TUBE YAMAHA BOND 1215
I have the parts now, but will not do anything unless my fix fails. Interestingly I measured the threads on the new shaft and they measured 17.80mm. I found the measurements I took when my sprocket fell off originally and it was 17.35mm
Lawrence
« Reply #21 on: 10 November 2012, 10:46:14 am »
Good news  :thumbup   Done about 3.5k on mine with the new nut and dodgy welding and it's holding up well.  I'm probably going to need a new chain/sprocket set soo though.
Cagey Thoughts
« Reply #22 on: 10 November 2012, 08:46:35 pm »
Thanks for the post..... just putting my Fazer back together and was looking at all the mod ideas..... so really useful.
I may be wrong, but did  i read somewhere about a different sprocket being released by Yamaha that was indented to take a wider nut?  I think it came out as a 'service update' in 2005?
The nut & washer kit went up from 9mm to 12mm on part number... 90891-10124, but I cant find the part number for the sprocket (if it exists)?
Only had the nut fail once since 2003... but.... belt n braces.... lol
« Reply #23 on: 10 November 2012, 10:57:31 pm »
I have never heard of a modified sprocket. I searched the American sites as the thundercat has the same sprocket and problems, but could only find mention of the FZ600 and that gave the modified nut. I am wondering, since Yamaha Ireland gave me the parts at half price it might open the door for those in the UK to do the same as a precedence has now been set.  Most people I spoke to are amazed I got anything, especially from Yamaha Ireland after 9 years and over 70000 miles. Anyway I'm not complaining to much.
I will keep the forum updated on how long my fix will last. It would be interesting if anybody else has tried the fix I posted in the downloads.
« Reply #24 on: 11 November 2012, 01:28:01 pm »
... did  i read somewhere about a different sprocket being released by Yamaha that was indented to take a wider nut?
I doubt it. If you look at Limax2's excellent drawing of the old and new nuts you can see the new one makes full use of all the thread available on the shaft.
