Date: 08-05-26  Time: 08:03 am
Author Topic: "ONLY" 45K!!  (Read 10079 times)
bradders086
"ONLY" 45K!!
« on: 05 September 2012, 01:41:50 pm »
Ive got a 2001 FZS600 and its been around the block more than a few times, this winter i intend to strip and recondition most of the engine. can i reset the clock??
Lawrence
Re: "ONLY" 45K!!
« Reply #1 on: 05 September 2012, 01:49:42 pm »
I hope not  :eek   Bear in mind it's (iirc) illegal to sell it when it's been clocked unless the buyer is aware of it.
bradders086
Re: "ONLY" 45K!!
« Reply #2 on: 05 September 2012, 01:57:16 pm »
im glad i found that out beforehand. i guess i'll just keep clocking the miles up
GringoRojo
Re: "ONLY" 45K!!
« Reply #3 on: 05 September 2012, 02:58:42 pm »
45k on a 2001? barely run in.
Gromit
Re: "ONLY" 45K!!
« Reply #4 on: 05 September 2012, 08:52:58 pm »
Could just buy a second hand clock with fewer miles on.
richfzs
Re: "ONLY" 45K!!
« Reply #5 on: 05 September 2012, 08:55:09 pm »
which is just as illegal as "clocking" it - you are mis-presenting the mileage the machine has covered. Unless you say the clocks have been switched of course, which makes the exercise pointless
Re: "ONLY" 45K!!
« Reply #6 on: 05 September 2012, 08:57:55 pm »
just keep riding it ;) .....another 55,000 miles and it will be new again  :rollin :rollin :rollin
His Dudeness
Re: "ONLY" 45K!!
« Reply #7 on: 05 September 2012, 09:13:42 pm »
you could install a time machine and go back to 2001
richfzs
Re: "ONLY" 45K!!
« Reply #8 on: 05 September 2012, 09:15:55 pm »
as others have said, a bit of tlc, and keep riding and enjoy it.
Ride more, worry less.
AdieR
Re: "ONLY" 45K!!
« Reply #9 on: 06 September 2012, 01:04:09 am »
Nope - resetting the clock is illegal.
Bear in mind, the mileage will be noted on MoTs anyway - therefore, if you're bikes mileage is 32K, and an old MOT says 35K, it'll get noticed sooner or later.
Re: "ONLY" 45K!!
« Reply #10 on: 06 September 2012, 09:11:44 am »
Is there something amiss, or are you planning on reconditioning the engine purely because it's reached 45,000 miles?
45k is high mileage, but only by comparison... the average bike owner keeps it as a toy and does a couple of thousand miles a year. The engine should last at least twice that before it needs anything major done.
Lawrence
Re: "ONLY" 45K!!
« Reply #11 on: 06 September 2012, 09:25:21 am »
Just press the Select button and look at the clock instead  :thumbup
Re: "ONLY" 45K!!
« Reply #12 on: 06 September 2012, 10:19:04 am »
Asking that on here is a bit like asking a policeman how to break into a house!  :rollin :rollin :rollin
bradders086
Re: "ONLY" 45K!!
« Reply #13 on: 06 September 2012, 01:06:52 pm »
Theres nothing wrong with it, i wanted a winter project and being a newbie to this kinda thing assumed (incorrectly) that if you recondition/replace bits you may be able to do something with the mileage........now i think of it what a knobish question!!
Re: "ONLY" 45K!!
« Reply #14 on: 06 September 2012, 01:17:18 pm »
The way you have to think of it is would you be happy paying top dollar for a 5000 mile bike, then finding out it's done 50,000 miles?  :rolleyes
Replacing a few bits and bobs doesn't mean the rest of the bike hasn't been through all weathers, have siezed bolts, and have general wear and tear, etc......
Strifae
Re: "ONLY" 45K!!
« Reply #15 on: 06 September 2012, 01:21:53 pm »
Mine had done 55k miles when I swapped it for a Gen2 FZ1 - I do actually regret it to an extend (not getting the FZ1 as its AMAZING) but I should have kept my FZS600 - it felt absolutely fine even with the high mileage - clutch was on its way out but everything else was bullet proof - I wouldn't have been surprised if it had done another 50k
If i knew who had bought it i would try and get it back again!
Re: "ONLY" 45K!!
« Reply #16 on: 06 September 2012, 09:01:18 pm »
Theres nothing wrong with it, i wanted a winter project...
OK. Well, unless you want to explore the bike's innards just for interest's sake (I've a friend who once took the gearbox out of his Citroen Xantia, dismantled it and put everything back together over the course of a 3-day weekend... purely for the pleasure of learning!), I'd leave the engine alone.
A possible exception is a check of the valve clearances, do you know when they were done? It's not something I can be bothered with these days because, in my experience, the valve seats and cam followers always seem to wear at near identical rates so the clearances stay unchanged, but it might be worth it for peace of mind.
I see you already have plans to clean up the brakes.
Other parts might benefit from dismantling and regreasing such as steering head bearings, swingarm and suspension bearings. Front forks might like an oil change, and a change of dust seals too. Then again, if the dealer can tell you these things have been done recently, I'd just leave the bike covered (maybe with the battery indoors and charged occasionally) and seize the opportunity to ride it every time the weather is fine... it's rare a month goes by without a few good days even in the depths of winter. :)
bradders086
Re: "ONLY" 45K!!
« Reply #17 on: 07 September 2012, 12:46:40 pm »
Thanks i might just stick to the basics
Revilo18
Re: "ONLY" 45K!!
« Reply #18 on: 07 September 2012, 03:28:04 pm »
Even in the depths of winter! As long as there's no ice on the side roads. Buy a nice set of gloves, a neck warmer and some thick socks! Fazers love the cold moist air and there's nothing like those crisp clear mornings. Also sunglasses for the low slung sun.
Garfy
Re: "ONLY" 45K!!
« Reply #19 on: 07 September 2012, 07:55:23 pm »
There is a service called (I think how many miles) that I used previuosly when my clocks went, I replaced them with a second hand set and had the mileage altered to the correct mileage on the bike. As somebody said its not the done thing to misrepresent milage but it can be done.
Bracechenko
Re: "ONLY" 45K!!
« Reply #20 on: 08 September 2012, 08:04:17 am »
Nothing like a bit of honesty lol :thumbup
bikerboys
Re: "ONLY" 45K!!
« Reply #21 on: 08 September 2012, 09:56:11 am »
high mileage :rollin got the bike with 67k on the clock had it for 9 months and now  on 76k  :lol  if there nothing wrong with the bike then do not fix it mine runs fine give it a tart up with some paint if it need s to be done and get shut of any rust.
 I was in two minds to change for a lower mileage bike but the mechanic I take it too said wots the point is there any thing wrong  with the bike now temping fate saying this  :lol but its mechanic soundand dose not look like a shed after I gave it a tart up  I have seen bike with 21k on the clock with a hole lot of problems and even fzs600 with 24k and 36k on the clock and they need engine work doing
Re: "ONLY" 45K!!
« Reply #22 on: 08 September 2012, 10:52:22 pm »
You would be wasting your cash because there would be nothing to recondition, except maybe replace the cam chain.
If its running ok then leave the engine intact.
Give a major service which should include the following:
Check the tappats, (vital) change the fuel, air and oil filters and change the oil, coolant and brake fluid.
I have seen these engines run to over 100000 miles, mine has just turned 72000 miles.
