Date: 02-05-26  Time: 10:04 am
Author Topic: cam chain tool  (Read 15018 times)
Mads
Re: cam chain tool
« Reply #25 on: 28 September 2012, 12:44:51 pm »
Hey thanks a lot for the explanation. Is it possible to change the cam chain guides from the top or do I need to remove engine from frame and remove the head to change those?
Cheers!  :)
Mads
Bias
Re: cam chain tool
« Reply #26 on: 28 September 2012, 12:59:27 pm »
The front chain guide can be taken out with a bit of wriggling if you remove the cams but the actual rear tensioner guide is at least a top end off/engine out/split job because of where its bolted at the bottom of the tensioner blade .... stunning design ..  ;)
Mads
Re: cam chain tool
« Reply #27 on: 01 October 2012, 10:17:44 am »
Ok, I will have to just change the chain and front guide then. Hope that will quiet it down. At this point I have no more clicks in the chain tensioner.
/Mads
