Date: 25-05-26  Time: 09:59 am
Author Topic: Sub Cowl - Silver Tech  (Read 4876 times)
MEM62
« on: 15 August 2012, 03:29:34 pm »
Does anyone know if these are available anywhere?
The part number is 5LV-W0714-30-00
MEM62
Re: Sub Cowl - Silver Tech
« Reply #2 on: 15 August 2012, 10:18:22 pm »
Yep, that's the one.  I was hoping to pick one up in Silver Tech but thanks for spotting the black one - I might have a bid on that.   :)
b1k3rdude
« Reply #3 on: 16 August 2012, 09:30:09 pm »
Do you mean a bellypan?
http://www.ebay.co.uk/itm/New-Unfitted-Black-FZS1000-Fazer-Bellypan-belly-pan-subcowling-FZS-1000-/140824976641?pt=UK_Motorcycle_Parts&hash=item20c9d29d01
http://www.ebay.co.uk/itm/2004-YAMAHA-FZS1000-FAZER-BELLYPAN-FZ1-FZS-1000-STREETFIGHTER-PROJECT-/221100832351?pt=UK_Motorcycle_Parts&hash=item337aa2f65f
Something to be aware of, I bought one of the 'pattern" black ones from cactus composites and of the two lower halves one side was thicker than the other. I spent ages bending the connecting brackets into slight s-shapes to accombate the extra thickness. Had I know this before getting it sprayed I would have sent back the offending side.
And the bottom of the second one has been smashed, possible beyond repair.
pitternator
« Reply #4 on: 17 August 2012, 06:41:47 am »
who would buy a cowl which is broken in half !!
karlo
« Reply #5 on: 17 August 2012, 08:32:04 am »
Me if it was cheap enough and I wanted one.
MEM62
« Reply #6 on: 17 August 2012, 11:06:16 am »
b1k3rdude
Thanks for the heads up on that.  I really wanted the original Yamaha accessory but, having looked for a while, I have not been able to source one.  I might still go for that if it is cheap enough because then I won't mind some fiddling around to fit it.
b1k3rdude
« Reply #7 on: 18 August 2012, 03:21:22 am »
Just contact the company (Cactus Composites) and tell them to make sure  that the two bottom halves are the same thickness, otherwise you'll have to do what I did.
Also when bidding you may want to factor in a few costs - belly pan cost £90 (should have stuck to the £75 budget), £150 getting it colour matched and powder coating on the brackets was £10. But when you consider the original Yamaha item new cost over £200 I don't feel to bad.
