Date: 11-05-26  Time: 12:42 pm
Author Topic: Carb balancing question  (Read 3007 times)
DryRob
« on: 15 August 2012, 02:31:03 pm »
I'm going to be balancing my carbs soon but am a bit confused about something.
The Haynes manual and workshop manual both tell me to adjust the idle speed the adjuster but neither mention the throttle position sensor (TPS) in pointer2nulls guide.
The question is, do I adjust both, one or neither?
ozpom
Re: Carb balancing question
« Reply #1 on: 15 August 2012, 03:08:22 pm »
Do both. I always follow pointer2null's guide (or one very like it) and it always makes a big difference :thumbup
The Haynes manual probably has the TPS adjustment in a different section :rolleyes
Andy FZS
« Reply #2 on: 15 August 2012, 09:32:22 pm »
pointer2null's guide ? :\
Andy
richfzs
« Reply #3 on: 15 August 2012, 09:42:37 pm »
DryRob
« Reply #4 on: 20 August 2012, 07:42:19 pm »
I've done it now, t'was easier than expected. Does the TPS need setting back to 0 RPM once I'm done? There seems to be a small delay between reving the throttle and the engine picking up now.
richfzs
« Reply #5 on: 20 August 2012, 09:41:54 pm »
Nope, should read 5k.... if it started at 0k, then was wrong before you started...
