Date:
26-03-26
Time:
08:20 am
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
Removing rear disc bolts
« previous
next »
Print
Pages: [
Author
Topic: Removing rear disc bolts (Read 2014 times)
old son
Naughty Corner
GP Hero
on:
01 August 2012, 08:12:04 pm »
A mate has got a GS1200 with a worn rear disc. The T40 bolts that hold it on are like cheese and semi recessed. This mate has rounded one and has asked how he can get it out. The disc is fitted to the hub so he cant take the wheel to his local engineering shop unless he can remove the hub. For this he will need an extractor!
Anybody have any ideas how he can remove the last bolt? I suggested warming the disc. Does it sound like that might work? He can't cut the head off because it is recessed and he can't tap the bolt round with a centre punch because its recessed.
Logged
Kosmic Kartman
Naughty Corner
GP Hero
Re: Removing rear disc bolts
Reply #1 on:
01 August 2012, 08:34:58 pm »
Can you get an arc welding rod to it? If so hit it with that. The sudden heat usualy breaks loose any seized bolts. Or cut a hex key and weld that to the bolt.
Logged
AdieR
Naughty Corner
Club Racer
Reply #2 on:
01 August 2012, 08:35:25 pm »
Pics would be handy if you have any.
Some heat on the bolt head will help soften the loctite on it, a key slightly bigger tapped into the bolt with a mallet might help, an impact driver can be useful too.
Logged
robby boy
Naughty Corner
WSB Pack Hound
Reply #3 on:
01 August 2012, 09:09:04 pm »
By T40 bolt I am presuming it is a Torx bit, I have removed rounded ones of these in the past by chapping in a spline bit and using a bit of heat. It might be worth giving the bolt head a smack with a drift and a FBH.
Logged
Tmation
Naughty Corner
GP Hero
Reply #4 on:
01 August 2012, 09:25:45 pm »
Some heat and a bit of impact are your friend.
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
