Date: 25-05-26  Time: 07:22 am
Author Topic: clutch knackered?????  (Read 2610 times)
bluefaze
« on: 26 July 2012, 09:16:08 pm »
clutch adjusted, everything fine, just biting where i want it, 10 minutes later lever full in to bar and she's pulling forward, rather quickly. not good in traffic, or anywhere really. sure i read about this but can't find it. please can some one help :(
AdieR
Re: clutch knackered?????
« Reply #1 on: 26 July 2012, 10:53:24 pm »
You say 10 minutes in the problem starts - my first thought is it's heat related; have you the right oil, and when was it last changed? Heavy oil can cause the plates to stick together. Have you tried re-adjusting the clutch?
« Reply #2 on: 27 July 2012, 06:55:22 am »
stretched,worn out cable not adjusted correctly...........easy and cheap to replace  :)
greeny
« Reply #3 on: 27 July 2012, 10:50:37 am »
Is it a new cable?
I replaced mine with a cheap one and the same thing happened. Went straight to dealer and brought a genuine cable. Much better.
Hope this helps.
Peter
