Date: 18-03-26  Time: 16:57 pm
Author Topic: front sprocket cover gasket  (Read 2907 times)
caretaker
« on: 07 July 2012, 03:52:11 pm »
just took off the sprocket cover to check whether the sprocket nut is the correct one, and the gasket falls apart. i went on the wemoto site but they only do the complete gasket set. anyone know where to get one or is it a case of make your own? ta.
born to be mild
Re: front sprocket cover gasket
« Reply #1 on: 07 July 2012, 04:45:04 pm »
Get one from your Yamaha dealer,  I did but Im not sure why as I dont really know what the gasket is for anyway. By the way, the genuine gasket comes with a protective backing which looks like it would do as a replacement as its the exact shape of the actual gasket so Ive kept mine thinking great, two for the exhorbitant price of one, but then Im tight anyway.
« Reply #2 on: 07 July 2012, 05:44:43 pm »
Just clean up the surfaces and bolt it back together, the gasket doesn't do anything useful.
You may find the clutch needs a slight adjustment as without the gasket the pushrod will be closer to the actuating mechanism on the sprocket cover.
caretaker
« Reply #3 on: 07 July 2012, 05:45:52 pm »
many thanks.
