Date: 11-05-26  Time: 17:59 pm
Author Topic: New Clutch Case Bearings  (Read 2455 times)
gel
« on: 06 July 2012, 01:09:41 pm »
I am doing some work on the olg girl (Fazer) and I am replacing the clutch casing with a new one I got off ebay. I need to know where I can get the oil seal and top bearing where the clutch actuator rod goes through the casing, also need the lower bearing inside the clutch case. I have checked WEMOTO but know joy, are they only available from Yamaha?  I think there was a link that Devilsyam put up for a company that did bearings but I cannot find it.
karlo
gel
Re: New Clutch Case Bearings
« Reply #2 on: 06 July 2012, 02:15:07 pm »
Right, contacted the company and as I did not have any bearing numbers then they were unable to help, so I rang my local yam dealer and have now got all the bearing circlips and washers comming. All sorted thanks.
