Date: 09-05-26  Time: 19:41 pm
Author Topic: Rear sets  (Read 13643 times)
renegaderacer
Rear sets
« on: 02 July 2012, 10:50:23 am »
Hi guys,
I'm converting my Fazer into a cafe racer and need some rear sets and don't fancy spending 340 odd quid on some Gilles ones!  :eek
Any cheaper suggestions?
Cheers,
Giles  :)
YamFazMan
Re: Rear sets
« Reply #1 on: 02 July 2012, 10:33:49 pm »
Hi
I made my own the 30x5 MS strip came from B&Q
They raise the footrests up 20mm and back10mm
https://dl.dropbox.com/u/70564722/img022.jpg
https://dl.dropbox.com/u/70564722/rearsets1.jpg
I used 8mm x 20mm cap head bolts to hold the footrests with a std washer between the Brk and the footest to give enough clearance for the head of Fazer bolts holding the Brk to the bike.
Edit :- In the photo I hadn't made the gearlink extension just moved the lever around the splines.
Heres a link to an earlier post :- http://foc-u.co.uk/index.php?topic=3007.msg24310#msg24310
ATB YFM
renegaderacer
Re: Rear sets
« Reply #2 on: 03 July 2012, 12:52:11 am »
Cheers YFM,
that's great!  ;)
I'll give it a go but without the use of a lathe or milling machine, I'm going to have to try with a hacksaw and angle grinder! LOL  :lol
YamFazMan
Re: Rear sets
« Reply #3 on: 03 July 2012, 12:53:15 pm »
Hi
No lathe or Milling M/c, Just a Hacksaw,a File or two ,a cheap pedestal drill a couple of drills and metric taps.
Come on you can do it  :D
ATB YFM
caretaker
Re: Rear sets
« Reply #4 on: 03 July 2012, 04:56:29 pm »
i've modified a few bikes over the years and used whatever was available. cbr600 rear sets are fairly cheap on ebay, but i would usually weld a suitable plate to suit. not something you can do on an assembled bike very easily though.
renegaderacer
Re: Rear sets
« Reply #5 on: 03 July 2012, 05:25:07 pm »
Hi
ATB YFM
Now, those tools I can do!  ;)
I'll give it a go at the weekend.  :)
Given my history of welding things; I think I'll try the first method!  :lol
Cheers,
Giles
renegaderacer
Re: Rear sets
« Reply #6 on: 15 July 2012, 08:55:53 pm »
Well, thanks to YFM's very helpful drawing, I've successfully made and fitted the riser plates and they feel great, although I still might get rearsets in the future when funds allow for an even racier position.
I was going to post pictures of them but my footrest hangers look horrible!  :lol
Anyone recommend something to clean oily, corroded, alloy hangers?
YamFazMan
Re: Rear sets
« Reply #7 on: 16 July 2012, 03:04:49 pm »
Hi
Well done I knew you could do it
Halfrauds have offers on large tins of ellbow grease  :rolleyes :lol
ATB YFM
andy352299
Re: Rear sets
« Reply #8 on: 16 July 2012, 06:16:30 pm »
i have just made a set of these myself
i used different dimensions.
basically new hole centres are back 15mm and up 20mm. and for my short legs they feel pretty good
i used 1 of these and a 6mm bolt with the head cut off to extend the gear change rod
http://www.ebay.co.uk/itm/221065976423
still have 9 left if anyone wants one
YamFazMan
Re: Rear sets
« Reply #9 on: 16 July 2012, 08:12:58 pm »
Hi Andy
Good idea for the gear link extension
ATB YFM
andy352299
Re: Rear sets
« Reply #10 on: 16 July 2012, 08:33:38 pm »
yer or i am just lazy
Hi Andy
ATB YFM
YamFazMan
Re: Rear sets
« Reply #11 on: 16 July 2012, 09:00:37 pm »
Hi
I also made some Rear Footrest Hangers that moved the footrests forward 50mm and down 50mm
The wife was getting cramp on the pillion.
 https://dl.dropbox.com/u/70564722/87.jpg
https://dl.dropbox.com/u/70564722/88.JPG
https://dl.dropbox.com/u/70564722/90.JPG
https://dl.dropbox.com/u/70564722/100.JPG
ATB YFM
Fazbaz
Re: Rear sets
« Reply #12 on: 16 July 2012, 11:15:47 pm »
Hi
ATB YFM
I've got a set just like them in the garage but made from stainless steel. I'll look tomorrow and if I can find them you can have them  :)
Baz  :D
renegaderacer
Re: Rear sets
« Reply #13 on: 17 July 2012, 11:09:28 am »
Hi
ATB YFM
Good idea. The missus is always complaining about cramp on longer journerys, so maybe I'll give it a go. On the other hand, if the standard set-up means I get more Sunday blasts without a pillion getting in the way........... ;)
YamFazMan
Re: Rear sets
« Reply #14 on: 17 July 2012, 07:09:52 pm »
Hi
I forgot to say you can get the 30mm x 5mm x 1m steel strip from B&Q
ATB YFM
Ben600
Re: Rear sets
« Reply #15 on: 18 July 2012, 08:52:22 pm »
just to add to this thread, I am in the process of adapting my SES rearsets from one of my Ducati's to fit the FZS. the bolt holes are only 2mm out, so a tiny amount of filing is needed :)  they may be an option for you too?
renegaderacer
Re: Rear sets
« Reply #16 on: 18 July 2012, 11:11:51 pm »
Hmmm, interesting.  ;)
Let me know how you get on!  :)
Giles
Ben600
Re: Rear sets
« Reply #17 on: 18 July 2012, 11:56:33 pm »
I will let you know, with pics... :) it hasn't been too hard making them fit.
I just now need to dig out my shift lever, as I much prefer 'race pattern' gear shift :)
FYI: these are what I am using, however it is possible that the ones designed for other yamahas may fit easier still? http://www.sesraceproducts.com/ducati-583-fixed-rear-set-rsd006-x-215-p.asp
YamFazMan
Re: Rear sets
« Reply #18 on: 20 July 2012, 05:03:39 pm »
Hi
With the Ducati rearsets fitted have you pushed the bike off the centerstand.
I seem to recall the lever that you put your foot on when operating the centerstand with my mod fitted came quite close to the footrest
and the Ducati ones look a lot further back and may clash with the centerstand foot lever.
ATB YFM
andy352299
Re: Rear sets
« Reply #19 on: 20 July 2012, 07:53:15 pm »
simular for me
the centre stand foot operating bit is very close to the gear change linkage.
Hi
ATB YFM
Ben600
Re: Rear sets
« Reply #20 on: 21 July 2012, 12:44:02 am »
Hi
ATB YFM
Hi,
To be honest with you, i took the centre stand off a couple of weeks back, as it ground out round corners. That said however, looking at where it used to sit and where the Ducati pegs fall, there is,or at least would be, more than adequate space between the centre stand and the new pegs.
When I get chance I will put pics up and complete the mini project, but things have gone a bit t*ts up my end atm, so the bike is taking a back seat.
renegaderacer
Re: Rear sets
« Reply #21 on: 21 July 2012, 12:40:54 pm »
It'll be interesting to see if it does clear the centre stand because even with YFM's brackets, I still had to adjust the gear change rod as ar as it'd go to miss the stand.
