Date:
11-05-26
Time:
23:44 pm
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
Starter
« previous
next »
Print
Pages: [
Author
Topic: Starter (Read 2548 times)
painterlad
Naughty Corner
CBT Wobbler
Starter
on:
28 June 2012, 06:53:13 pm »
Help.....My FZ1n seems to have developed an annoying habbit of not always starting when I press the button. It seems to be an intermittent affair as usually after a couple of goes it does start, but I am waiting for the time when I refuel and it doesnt. Any suggestions as to what may be causing this? thankyou in advance
Logged
mcyoungy
Club Racer
Re: Starter
Reply #1 on:
28 June 2012, 06:55:36 pm »
clutch switch, sidestand switch - those would be my first ports of call. kill switch can cause the same - best thing is not to use it.
give them a clean with some contact cleaner.
Logged
ghostbiker
GP Hero
Re: Starter
Reply #2 on:
28 June 2012, 08:09:38 pm »
might also want to give the contacts a clean in the starter button itself to.
Logged
AdieR
Naughty Corner
Club Racer
Re: Starter
Reply #3 on:
28 June 2012, 08:43:27 pm »
When it happens, does it turn over properly? Is it sluggish turning over (or dead)?
How old is your battery? (ie, is it feasible that its on its way out?).
Logged
painterlad
Naughty Corner
CBT Wobbler
Re: Starter
Reply #4 on:
29 June 2012, 05:26:09 pm »
Thanks for the help. I shall try all the options.
Logged
monkeyb0b
Cager in Training
Re: Starter
Reply #5 on:
08 July 2012, 09:43:59 am »
Did you get anywhere with this?
Mine has started to do something similar. I press the starter button there is a click from what sounds like the motor and nowt happens. Sometimes it fires on the first go other times i have to try 6 / 7 times and then it fires up
Logged
garysimmo
DAS Born Again
Re: Starter
Reply #6 on:
08 July 2012, 03:21:18 pm »
First port of call check and clean the 30amp fuse under the seat, its attached to the starter solenoid, the get quite furred up.
Logged
Print
Pages: [
« previous
next »
Starter
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
