Date: 19-04-26  Time: 08:08 am
Author Topic: Powder coating wheels  (Read 7671 times)
adeejaysdelight
« on: 16 June 2012, 02:57:43 pm »
The wheels on my little 125 run-about have started to corrode on the inside and can't hold the air in the tyres (after only 10,000 miles in all but the worst of weather). I was going to buy some replacement wheels from ebay, but there is nothing to say they won't suffer the same fate. I heard powder coating the wheels will resolve the issue. I have also read powder coating wheels can cause them to weaken. Both options will cost the same, so money is not a factor. Have any of you Foccers done this before, and if so, what was your experience?
goldfazer
Re: Powder coating wheels
« Reply #1 on: 16 June 2012, 03:14:07 pm »
Is it possible to put tubed tyres on?
adeejaysdelight
« Reply #2 on: 16 June 2012, 06:37:52 pm »
I don't know, but I have not long (600 miles) put on a pair of Continental tyres that cost more than the powder coating/new wheels would cost. It would be a waste not to use them and spend said monies on a new tyre set up when the wheels remain f***ed.
GrahamB
« Reply #3 on: 16 June 2012, 08:16:26 pm »
Have you allowed for new bearings & possibly disc bolts? Factory disc bolts seem to be made of really cheap steel & are thread locked in so removing the discs is normally enough to destroy them (for me at least).
 Think I have had the wheels of every bike I have owned coated if they weren't already but if yours look okay externally I might be tempted to remove the tyres, rub the inner rims down smooth, splat a bit of primer on or primer & colour if you want to be posh then stick tyres back on.
robby boy
« Reply #4 on: 16 June 2012, 09:45:43 pm »
You could take the tyres off and give the rim a good rub with emery/sand paper then buy "tyre rim bead sealer" off evil bay, we use the Rema Tip Top (other makes available :b ) on cages at work, (stuff is like a very runny silicone that dries in about a minute and seals any imperfections on the rim,)seems to hold for about a year, either that or get local tyre repair shop to do it for you.
« Reply #5 on: 17 June 2012, 07:41:01 am »
could you clean the rim up and put tubes in using the tubeless tyres  :) ...iam pretty sure ive done this before....just cost you the price of two tubes and a little time  ;)
karlo
« Reply #6 on: 17 June 2012, 08:01:03 am »
I would get the tyre off, flat off the inside of the rim, mask off the outside, etch primer then spray it with colour a lot cheaper than powder coating.
Wilko
« Reply #7 on: 18 June 2012, 11:24:31 pm »
Agreed it's cheaper, but in my experience does not last anywhere near as long. normal paint chips far to easily.
taksi
« Reply #8 on: 19 June 2012, 03:23:49 pm »
Have a look here. www.triple-s.co.uk.
Taksi
adeejaysdelight
« Reply #9 on: 27 June 2012, 08:01:26 pm »
Thanks a lot for all your help peeps. Still not decided, but I get payed tomorrow, so it will be done in the next week of two.
Pictures to follow... :D
