Date: 11-05-26  Time: 01:52 am
Author Topic: Creaking front suspension  (Read 3593 times)
bigfootpete
« on: 10 June 2012, 09:00:08 pm »
When I turn the handlebars my front suspension makes a creaking noise that seems to be getting worse, anyone come across it before? Lack of lube?
CRH
Re: Creaking front suspension
« Reply #1 on: 10 June 2012, 09:06:31 pm »
sounds like your head bearings need a spot a grease???? :rolleyes
bigfootpete
« Reply #2 on: 10 June 2012, 09:16:25 pm »
Well, it's definitely due for a service - hopefully that's all the problem is... Thx!
bludclot
« Reply #3 on: 10 June 2012, 10:16:42 pm »
this could be something as simple as a part of the loom or a control cable sheath rubbing against one of the leg tops. some simple further investigations with a piece of cloth slipped in each of the touching areas in turn might well reveal a culprit...?
bigfootpete
« Reply #4 on: 08 August 2012, 08:08:51 pm »
Update - turns out it was the front brake - right pad was worn right down, didn't even notice a problem braking :-)
Expensive service though - £250, think I also need to re-lube the exup as it doesn't look like he touched it...
3 hours labour...
alan09
« Reply #5 on: 08 August 2012, 08:47:55 pm »
Expensive service though - £250,...
silly question, but what excactly do you get in a service for £250 that you cant do yourself.
bigfootpete
« Reply #6 on: 08 August 2012, 09:31:47 pm »
Pffft, I know bugger all about engines, and I have massive hands that are shit at getting into tight spaces. I'd rather leave that up to someone who has the space, time and knowledge to not stuff it up.
Although saying that he probably just replaced the oil and filter, brake pad, checked the plugs and adjusted the chain and lubed everything up...
I don't know what else he may have checked.
alan09
« Reply #7 on: 08 August 2012, 09:57:58 pm »
and your £250...if all they do is oil & filter change, check & or replace brake pads + new plugs, i'm really neanderthal  when it comes to mechanics but all of these jobs are/seem quite straight forward.
