Date: 02-05-26  Time: 12:23 pm
Author Topic: exhaust question  (Read 2733 times)
tex1507
exhaust question
« on: 10 June 2012, 12:02:44 pm »
my 02 fazer is running a hi flo filter, sandy spares stainless down pipes and a scorpion end can with removable baffles.
i haves just serviced the bike and balanced the carb's so the question  is if i run the bike without the baffles in what long term effect is it going to have on the engine or can the fazer engine take it?
cheers
stu
CRH
Re: exhaust question
« Reply #1 on: 10 June 2012, 04:01:31 pm »
i found with mine?(running similar set up as yours)...that without the baffle mine felt realy flat??....and popped back realy bad on over run?..but with baffle runs perfect??.....if your mixture is ok and its not running over lean then cant see long term damage of any sort occuring??....if any it will be your ears!! that will suffer :'(
jason1
« Reply #2 on: 10 June 2012, 04:07:58 pm »
Been running mine without baffles for over six months and all seems good
tex1507
« Reply #3 on: 10 June 2012, 05:21:13 pm »
Cheers both getting fed up of half asleep car drivers trying to  occupy the same piece of road as me on early morning runs down the motorway.
just did not want to bugger my bike up as it is running sweet at the mo
Silverdream
« Reply #4 on: 10 June 2012, 05:23:53 pm »
Yep ... agree with above.. running mine with out baffles and hi flow filter.. pops nicely on decel.. and keeps the lane hoggers awake when im filtering on the way to and from work ...  :lol
Dead Eye
« Reply #5 on: 10 June 2012, 10:02:30 pm »
Same here - K&N hi flow filter, Sandy Spares Stainless Steel pipes and Beowulf Warrior end can. I've run mine without the baffle since day 2 - I had it in for day 1 and wanted it a bit louder ;) No popping on mine though, but obviously its a different can. The only trouble you'd maybe experience is under-fuelling due to higher percentage of air in the mixture. It's not likely as the fazer over-fuels as standard and if you do experience any trouble, just pop the baffle back in :)
