Date: 21-03-26  Time: 12:14 pm
Author Topic: What changed in 2004/5 Fazer Thou's?  (Read 4910 times)
MadDogMcQ
« on: 06 June 2012, 01:18:54 pm »
I've noticed on a few parts/accessory sites that they differentiate between 01-03 and 04-05 FZS1000's.  Why?
mcyoungy
Re: What changed in 2004/5 Fazer Thou's?
« Reply #1 on: 06 June 2012, 01:33:06 pm »
carb needle spacers changed in 03.
frame colour changed for 04 I think.
ghostbiker
« Reply #2 on: 06 June 2012, 02:27:03 pm »
might have been 03-04 the electrics changed VERY slightly with the loss of the headlight switch. or was that 02-03?
to be honest there were very few changes on any of the years and 90% of those were minor/cosmetic/colour
mcyoungy
« Reply #3 on: 06 June 2012, 02:28:31 pm »
good one - my 04 didn't have the light switch.
rjd1
« Reply #4 on: 06 June 2012, 02:41:39 pm »
my 53 plate aint got headlight switch
MadDogMcQ
« Reply #5 on: 06 June 2012, 03:40:35 pm »
Thanks for the replies. Nothing to worry about then.
squitbit
« Reply #6 on: 07 June 2012, 10:39:36 pm »
Anyone know if they changed the clutch lever? I've bought 2 off ebay for my 54 plate, both wrong. Pivot hole too small and the 'meat' around the pivot around 5mm too thin (as in the thickness of the metal around the pivot, measured flat to flat). Surprised me
ghostbiker
« Reply #7 on: 07 June 2012, 11:20:28 pm »
not aware of any changes to leavers. i replaced mine with no issues
mcyoungy
« Reply #8 on: 07 June 2012, 11:28:52 pm »
Sounds like your clutch perch has been changed at some point. The clutch lever is the same for all years up to 2012 and R1 99-08:
http://www.yamahamotorcyclespares.co.uk/spares/partImage.asp?GPN=Z9%5D%5B%3D8%3E676655&uid=0&ShowAll=1
98 R1 perch and lever are different so *could* be one of them is on there.
chitsu
« Reply #9 on: 08 June 2012, 09:39:01 am »
The fork seal is thinner on the 04-05 (1C2 is it's model code). It is  9.5/10.5mm as opposed to 11/14.5mm of that fitted to the 5LV  :eek
Also the full wiring loom & ignition switch is different (due to the lack of a headlight switch).
squitbit
« Reply #10 on: 08 June 2012, 12:02:13 pm »
I've had the bike since new and the clutch perch definitely hasn't been changed.
mcyoungy
« Reply #11 on: 08 June 2012, 12:28:42 pm »
wiring harness changed at 03.
karlo
« Reply #12 on: 08 June 2012, 02:34:53 pm »
Mine is an 03 without light switch.
mcyoungy
« Reply #13 on: 08 June 2012, 02:41:15 pm »
must be duff parts then eh?
pitternator
« Reply #14 on: 09 June 2012, 07:43:00 am »
I had an 01 bike, and now an 04 ..almost nothing diffrent apart from tank logos and no on off switch for the lights. I cant tell anything more minor than that.
If you buy clutch levers off e bay its possible the seller has given you the wrong one.??
MadDogMcQ
« Reply #15 on: 10 June 2012, 09:42:03 am »
Just found this...
In 2001 FZS1000 Fazer launched: R1 engine
and brakes, basic but capable chassis. The first Fazer 1000 was a massive hit. 143bhp at the crank – typical bikes dyno 122bhp at the rear wheel.
In 2003 it becomes available with a black engine (designation FZS1000S) and gets an updated instrument panel.
In 2004 the model code changes from 5LV to 1C2 but there are no significant technical changes.
In 2005 black frame, ECU and catalytic converter changes to cope with the latest emission regs.
Tom
rjd1
« Reply #16 on: 10 June 2012, 02:23:41 pm »
mine is 53 plate
no light switch
 black frame
 black engine
bwizz
« Reply #17 on: 10 June 2012, 08:11:37 pm »
There was a restrictor in the exhaust collector in my 05 , which i believe was not fitted to the earlier models. I've removed it
just held in with spot welds.
