Date: 01-05-26  Time: 10:06 am
Author Topic: Temperamental tail brake light...  (Read 2100 times)
Buzz
« on: 03 June 2012, 06:42:30 pm »
Afternoon...
I checked my rear brake light this morning and something's wrong.   The lever gives a "click" as if the microswitch is opening but the tail light doesn't immediately turn on, it's only when I squeeze a good 2cm past the "click" does it come to life.  What's more worrying is that it doesn't come at all in 1 out of 4 squeezes  :eek
I'm guessing the light is meant to come on at the "click"?  The rear pedal works fine BTW and activates the light straight away.
Microswitch problems?  I might take it out and give it a clean when it stops raining on Tuesday.
Bracechenko
Re: Temperamental tail brake light...
« Reply #1 on: 03 June 2012, 07:55:24 pm »
The microswitch will be corroded and needs replacement. I know because mine just failed an MOT and no amount of WD40 helped. The mechanism still worked but when I removed and split open the insides were completely corroded and oxidised beyond repair.
The good news is that a replacement cost less than a fiver from Ebay, is easy as pie to fit (1 screw holds the switch in place) and it did the trick perfectly :thumbup
bikemad62
« Reply #2 on: 03 June 2012, 08:03:37 pm »
I would go with the replacement plan. I got an led rear light and had the same problem  changed it and job done.
