Date: 18-03-26  Time: 15:09 pm
Author Topic: changing air filter - easy ?  (Read 6567 times)
Enceladus
« on: 01 June 2012, 08:26:22 pm »
planning on changing the oil, filter and putting in a mag drain plug this weekend, and that got me thinking (yes, i know that's dangerous !)
i would doubt that the air filter has been changed recently and could probably do with being replaced.
is it an easy thing to replace ?
don't mind a bit of work, but would prefer not to have to remove the tank ifi can help it.
Andy FZS
Re: changing air filter - easy ?
« Reply #1 on: 01 June 2012, 09:54:19 pm »
It's not difficult................once you've removed the tank
« Reply #2 on: 02 June 2012, 11:14:45 am »
Air filter is easy enough to replace, easier than the oil filter in my opinion... or at least that was the case with my adventures...
It's located underneath the fuel tank, just in front of the battery :)
fishwibbler
« Reply #3 on: 16 June 2012, 12:11:35 am »
Yep, if memory serves, undo one bolt, prop up the tank carefully on a piece of wood then do the necessary.
If you have a carb Fazer, I hope you have a K&N filter to liberate the midrange?
Good luck amigo,
fish.
« Reply #4 on: 16 June 2012, 02:03:45 am »
NO propping, take tank off, then procede  :eek
« Reply #5 on: 16 June 2012, 08:00:07 am »
yea tank off jobbie....be carefull not to trap the two breather pipes when re-fitting.and to make the job a little easier wait until the tanks nearly empty  ;)
jason1
« Reply #6 on: 16 June 2012, 05:25:59 pm »
Tank OFF , easy job
Oxygen
« Reply #7 on: 16 June 2012, 06:20:20 pm »
Easy and the manual is in the forum somewhere.
Enceladus
« Reply #8 on: 16 June 2012, 06:23:50 pm »
thanks for the replies :)
was hoping not to have to remove the tank, but looks like i have little option.
k&n on order :D
