Date: 24-05-26  Time: 18:21 pm
Author Topic: Cage trouble  (Read 2514 times)
pete786.u
Cage trouble
« on: 31 May 2012, 07:58:32 am »
 :car Parked up at the local Garden Centre yesterday, went to start the car and couldn`t release the steering lock or turn the ignition key. Called the AA and the guy had to butcher the ignition barrel trying to sort it out. Ended up with a hot wire system to keep me going.
 The outcome is that I need a new ignition barrel and probably a new steering column :'( Imobilisor still works as does all the other electrics except the clock and outdoor thermostat.(fuse ?)
 May end up fitting a switch for the ignition and a push button for the starter motor and forget the steering lock and new ignition barrel.
GringoRojo
Re: Cage trouble
« Reply #1 on: 31 May 2012, 03:00:16 pm »
so when will you realise it wasn't your car but an identical one parked where you thought you'd left yours?
pete786.u
Re: Cage trouble
« Reply #2 on: 31 May 2012, 05:27:27 pm »
Phoned my local main agent today to see what the parts would cost  :eek £672.62. I think the car will be on it`s way to the scrapyard in the next few weeks, Tax runs out end of July MOT next February the cars not worth spending that much money on it so it`s going.
GrahamB
Re: Cage trouble
« Reply #3 on: 31 May 2012, 07:47:54 pm »
This happened to a family member last year. I was able to remove the ignition barrel assembly, identify the worn pins, remove them & put it all back together. I think a combination of worn pins internally & worn key were enough to stop it all from doing the business. I would be tempted to phone a few local breakers before ditching the car myself... .    unless you're looking for an excuse to ditch it that is?
robby boy
Re: Cage trouble
« Reply #4 on: 31 May 2012, 11:19:39 pm »
What type of car is it, secondhand parts might be readily available cheap.
Lawrence
Re: Cage trouble
« Reply #5 on: 01 June 2012, 11:26:45 am »
Get bits from a breaker/ebay, will be far cheaper than going to a dealer.
