Date: 14-07-26  Time: 07:19 am
Author Topic: TPS setting  (Read 9083 times)
mcyoungy
TPS setting
« on: 16 May 2012, 12:54:35 pm »
Am I right in thinking that the static setting that equates to Ivan's method is to set the TPS so that the tacho flicks between 5k and 10k?
And what size are the screws? I just mullered one.
Thanks
Falcon 269
Re: TPS setting
« Reply #1 on: 16 May 2012, 01:35:16 pm »
Yes, either method you mention will achieve the effect of advancing the standard ignition curve.  Ivan's method is more engine-led.  The tacho method is more neighbour-friendly. :)
T-20 Torx, IIRC.  Sorry, don't know the actual screw size in mm.
mcyoungy
Re: TPS setting
« Reply #2 on: 16 May 2012, 05:42:44 pm »
thanks Mike, much appreciated.
cable tie
Re: TPS setting
« Reply #3 on: 16 May 2012, 09:45:01 pm »
Mike have you tried pats method of running the bike @ 3800 rpm and make adjustment to tps !! if so did you see any improvement over the 5k tacho setting, Ive set mine bang on 5k, but wonder if pats prefered method works better.
Ive also got a 3 degree ignition advancer fitted, so setting my tps to 5k is correct!!
Dave.
solorider
Re: TPS setting
« Reply #4 on: 16 May 2012, 10:43:08 pm »
looking on the yamaha service manual when the rev counter shows 5k the tps is in the correct position,if the rev counter shows 0rpm then the angle is too small,if it shows 10k then the angle is too big
mcyoungy
Re: TPS setting
« Reply #5 on: 16 May 2012, 10:45:43 pm »
yeah but...................... according to Ivan et al if you set the TPS so it's flicking between 5k and 10k then you've got some ignition advance, giving a crisper throttle response.
Falcon 269
Re: TPS setting
« Reply #6 on: 16 May 2012, 11:15:11 pm »
Dave.
What Pat describes on his site is Ivan's method. :)  I've tried 'em all, as you can imagine.
Without an ignition advancer, you get much the same outcome using either Ivan's method or the 5-10k flicker on tacho approach.
With the advancer, I set mine at 5k rpm on the tacho.
cable tie
Re: TPS setting
« Reply #7 on: 16 May 2012, 11:21:48 pm »
Thanks Mike  ;)
My bike has very crisp throtle responce and after syncro the carbs is very smooth pulls top gear 25mph nicely and i can crawl at walking pace without feathering the clutch, than give it some chicken and it has a very strong power delivery, its very deceptive how quick it is, But i still got some vibs i can feel em in the tank, i suppose ill have to live with em .
Dave  :D
mcyoungy
Re: TPS setting
« Reply #8 on: 16 May 2012, 11:38:11 pm »
well I bit the bullet and spent 3 quid on a T20 security Torx driver. I'll probably scrap less screws than by hammering a regular Torx into them.
Falcon 269
Re: TPS setting
« Reply #9 on: 17 May 2012, 06:25:53 am »
The cheap trick is to use a small jeweller's screwdriver as a chisel to remove the nub in the security Torx screw.
You didn't hear that from me ... ;)
mcyoungy
Re: TPS setting
« Reply #10 on: 17 May 2012, 08:37:30 am »
too much finesse there Mike   :lol  ............... I found that using a persuader on a regular Torx bit flattened the tit enough to get the screw to shift... til I overtightened it  :rolleyes
