Date: 09-05-26  Time: 08:34 am
Author Topic: running richhi  (Read 5458 times)
reggae123
running richhi
« on: 16 May 2012, 10:56:42 am »
what would cause a bike to run rich (bike starrted ok today kinda lol)
mcyoungy
Re: running richhi
« Reply #1 on: 16 May 2012, 01:04:48 pm »
blocked air filter.
reggae123
Re: running richhi
« Reply #2 on: 16 May 2012, 01:59:29 pm »
airfilter is fine the carbs do have cracks in quite bad ones
topgun44
Re: running richhi
« Reply #3 on: 16 May 2012, 04:58:53 pm »
600 are bit lean on runing  ;)
mcyoungy
Re: running richhi
« Reply #4 on: 16 May 2012, 05:43:34 pm »
cracked carb rubbers will make it run lean, not rich
Re: running richhi
« Reply #5 on: 16 May 2012, 06:20:02 pm »
cracked inlet rubbers are a common fault on 600 fazers,they are very thick and its a fair bet that there not cracked all the way through.and as MCYOUNGY has already said will make the bike run lean not rich   :)
mcyoungy
Re: running richhi
« Reply #6 on: 16 May 2012, 06:52:08 pm »
worn emulsion tubes would cause rich running. float level too high.
how do you know it's running rich?
reggae123
Re: running richhi
« Reply #7 on: 16 May 2012, 08:47:05 pm »
the spark plugs are sooty so changed them
Andy FZS
Re: running richhi
« Reply #8 on: 16 May 2012, 10:07:11 pm »
Choke stuck or partly stuck on?
reggae123
Re: running richhi
« Reply #9 on: 16 May 2012, 10:27:39 pm »
choke works  as it should
bikemad62
Re: running richhi
« Reply #10 on: 17 May 2012, 02:17:45 pm »
Take the choke plungers out and get a magnifing glass and look at the rubber seal faces for wear or cracks. just because they move don't mean they "ain't" damaged !!!!
bikemad62
Re: running richhi
« Reply #11 on: 17 May 2012, 02:28:46 pm »
Other advice would be. Strip them down clean and rebuild paying close attention to worn moving parts. such as jet needles, sliders and diaphrams. There are a surprising amount of moving parts in there. and always use a magnifying glass. The damage may be hard to see with the naked eye. My son had a small split in one of his slider diaphram and neither of us saw it until i magnified it. caused all sorts of problems. hope this helps.
reggae123
Re: running richhi
« Reply #12 on: 17 May 2012, 03:00:56 pm »
ok and how on earth would i do that will it help my bike to start better
mcyoungy
Re: running richhi
« Reply #13 on: 17 May 2012, 03:12:27 pm »
what starting problem do you have? hot or cold?  what mileage is on the bike? when were the valve clearances checked?
reggae123
Re: running richhi
« Reply #14 on: 17 May 2012, 04:29:54 pm »
no idea when the valve  clearences were last cheked i have noticed when u turn the ket in the igntion u have to wait for the ist click noise to click then the bike starts is thgat normal ie is that click sound the petrol pump cheers
Gnasher
Re: running richhi
« Reply #15 on: 18 May 2012, 01:38:39 pm »
Is it rich at idle and below 3k or above 3k?
bikemad62
Re: running richhi
« Reply #16 on: 21 May 2012, 09:06:18 pm »
Get a haynes manual for a start. If the needles on the sliders are worn they will let more petrol through and that may cause the rich mixture.
